Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Select Hobbies SkiniWag build thread
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 07-23-2014, 05:47 PM
hfenn
Next I bent the landing gear wire best I could to the shape on the plan and assembled the box it fits in. Then I glued it and the forward brace for it into the fuselage.
Name:	IMG_2076 (640x480).jpg
ID:	2016651   Click image for larger version
Name:	IMG_2077 (640x480).jpg
ID:	2016652   Click image for larger version
Name:	IMG_2078 (640x480).jpg
Old 07-23-2014, 05:48 PM
hfenn
Here's a nude photo to drool over while I plan my radio install.
Name:	IMG_2079 (640x480).jpg
Old 08-01-2014, 07:26 PM
hfenn
Backing up a bit, I put in the rear landing gear braces that should have been installed earlier.
Name:	IMG_2080 (640x480).jpg
Old 08-01-2014, 07:28 PM
hfenn
Next I glued in the 9 gram servos. I installed an AR 6110 end pin Rx and BEC in the area in front of the servos. The 2S LiPo will go in ahead of the landing gear. Then I glued on the bottom wing.
Name:	IMG_2081 (640x480).jpg
ID:	2019295   Click image for larger version
Name:	IMG_2083 (640x480) (2).jpg
Old 08-01-2014, 07:30 PM
hfenn
Glue the R2 ribs in line with the fuselage sides. Cap the wing and fuselage bottom with the 1/16" X 3/4" balsa. I'm leaving the front open for now and will make a hatch for battery access. Trim the bottom sheeting to the fuselage sides and hinge the tail surfaces.
Name:	IMG_2085 (640x480).jpg
ID:	2019297   Click image for larger version
Name:	IMG_2086 (640x480).jpg
ID:	2019298   Click image for larger version
Name:	IMG_2087 (640x480).jpg
ID:	2019299   Click image for larger version
Name:	IMG_2088 (640x480).jpg
Old 08-01-2014, 07:32 PM
  #31
hfenn
Next I'll paint the parts before gluing it all together. I plan to use butyrate dope.
Old 08-06-2014, 02:17 PM
  #32
RRGeoSmith
Mine is almost under powered with a PAW .03 but yours is going to be a rocket with the Tee Dee. You might ought to put the throttle on it before flying. I have a few extra throttle sleeves so if you need one just let me know.
Old 08-06-2014, 05:01 PM
  #33
hfenn
Thanks George! I have one on hand if I need it.
Old 08-06-2014, 07:30 PM
  #34
Pond Skipper
Pond Skipper's Avatar
Under Cambered airfoil should be a lift monster, yet two wings causes a compression zone between the wings which allows it to sit somewhat.
Old 03-16-2015, 05:10 PM
  #35
hfenn
Finally got some color on it!
Name:	IMG_2204 (640x480).jpg
Old 03-16-2015, 06:57 PM
  #36
Pond Skipper
WTG not far to go now post a vid when ready if able = )
Old 03-17-2015, 04:39 AM
  #37
RRGeoSmith
SMALL is getting closer. Can't wait to see it fly.
Old 03-17-2015, 07:32 AM
  #38
skaliwag
skaliwag's Avatar
Really like the base colour. Would look good in Basic Trainer livery.
If you are going to do a vid, keep away from the bees.
Old 03-21-2015, 02:52 PM
  #39
Tee Bee
Nice work, Hollis. Hope to see it this June.
Old 03-21-2015, 03:11 PM
  #40
hfenn
Thanks Troy, that's my plan!
went to spay some black trim and the dope had congealed in the bottle hopefully I can find a hobby shop close by that has some. See ya!
Old 04-24-2015, 01:51 PM
  #41
hfenn
Weighs a skosh over 9 ounces. Test flight(s) soon!
Name:	IMG_2230 (640x480).jpg
Old 04-24-2015, 02:29 PM
  #42
combatpigg
combatpigg's Avatar
Very nice Hollis..!
9 ozs is incredibly light for a plane that size, it ought to be a joy to fly.
Old 04-24-2015, 03:58 PM
  #43
RRGeoSmith
Looks great Hollis. Mine weighs just over 10 ounces with a throttled PAW .03. It flies great. Plenty of power but not enough to get in trouble. Thank Goodness!
Old 04-24-2015, 04:02 PM
  #44
Tee Bee
That looks nice! Well done.
Old 04-24-2015, 04:31 PM
  #45
skaliwag
skaliwag's Avatar
May need extra Down Thrust with the TD's extra umph..
Old 04-24-2015, 09:41 PM
  #46
Pond Skipper
The white Tornado is a 4P you may want to fly with a 3P in lieu of the design. Well done I hope you enjoy it!
Old 04-25-2015, 07:33 AM
  #47
hfenn
Thanks for the compliments guys. That particular TD is no ball of fire; compression is a little low. I may swap out the cylinder and piston assembly.
Pond Skipper, That prop is marked 6X3, but I always experiment with different props to find one that best suits the plane. I know the bipe is going to want thrust rather than speed.
Old 04-25-2015, 08:41 AM
  #48
Pond Skipper
Ahh ok its the black ones that are 6 x 4
Old 05-11-2015, 05:30 PM
  #49
hfenn
Uploading video to youtube, will post it soon. Best watched full screen and HD.
https://www.youtube.com/watch?v=Vr245ZhFq-k&feature=em-upload_owner#action=share
Old 05-11-2015, 08:26 PM
  #50
combatpigg
combatpigg's Avatar
That's a great looking plane and a great looking place to fly..!
