VINETIAN BLIND
RE: VINETIAN BLIND
ORIGINAL: goirish
We are getting close to putting this puppy in the air. Servos are mounted. Ailerons working. Brushless motor. Will post a video if it flys. If it don't I won't post the video. See how brave I am.
RE: VINETIAN BLIND
ORIGINAL: dieFluggeister
A lot can be learned from an autopsy video - perhaps enough to make a few changes and give success!
MO
RE: VINETIAN BLIND
If you find the aileron effectiveness marginal try this:
reverse the throw direction and the servo input to have one side go up this would be the opposite side of desired roll.
this works by reducing lift on the wing with raised aileron and allows the opposite wing to come up. I have not tried it but guys using separate servos on glider spoilers do this occasionally to get the spoilers to work like ailerons.
Thats one cool looking old plane! we definately want at least a report on the maiden.[8D]
RE: VINETIAN BLIND
The problem is the way the plane was designed to fly. As a CL trainer, it flies on some of the slats, not all of them. Which slats gives it lift depends on the attitude of the plane. If full up is given, the plane is supposed to fly on the front slats, while the rear slats supply drag so the plane can mush into the ground, avoiding a crash.
As an RC with ailerons, who knows? We can only wish him success.
George
George
#31
RE: VINETIAN BLIND
I see what you mean, it will fly on the three rear slots only with the four foremost ones at negative/neutral angle of attach. The aileron surface have been added though so with a proper tuning of their neutral poistion, surely there will be a difference in lift between the two wing halves and the plane will bank....?
If it doesn't work one could always just cover the whole thing and get an under chambered wing!
#32
RE: VINETIAN BLIND
Humm!! why are you saying different lift on the 2 wing halves. Don't understand that. Seems like adding the ailerons should give it more lift in the level position.
#33
RE: VINETIAN BLIND
Maybe I need to mount a 4 stroke on it so it will have enough power to drag it through the air. hahahaha--thinking maybe a 91 ought to do it.
#34
RE: VINETIAN BLIND
I will post a video when we maiden it. That way we can all have a big laugh. Some can say "I told you it wouldn't fly". Waiting for the weather to break. However, they are calling for 6" snow by tonight again. But you know Michigan only has 2 seasons. Fall & Winter.
#35
RE: VINETIAN BLIND
ORIGINAL: goirish
#36
RE: VINETIAN BLIND
ORIGINAL: goirish
I think we all are anxiously awaiting flight reports!
George
#37
RE: VINETIAN BLIND
you are correct gcb. Trying to fit all of the electronics has been a nightmare. But we are getting close. Just trying to figure out what battery to use for this brushless outrunner.
#38
RE: VINETIAN BLIND
ORIGINAL: goirish
My guess is that the ailerons will be effective when the plane is level but less effective as you take off and land. Just a guess, you can soon answer those questions. Good luck.
George
