Herr Little Extra+a lil Xtra
#101
RE: Herr Little Extra+a lil Xtra
ORIGINAL: N1EDM
Hi Matt,
I can't say that I played around with a lot of props when I had the OS-10LA in there. I was using wood props. And, I was using 10% fuel, I think (but am not sure).
I'm just at the point of mounting the new engine and was going to drop in the Magnum 15 but you may have given me 2nd thoughts on the OS-10LA. What size prop were you using? I wonder if the OS-10LA can handle a lot of nitro because I have some 25% nitro hanging around somewhere.
Bob
Hi Matt,
Bob
#102
Well, I just got through working on the Herr for the evening. I got out the 10LA and then remembered that I had already cut the mounting cheeks for the Magnum 15, so I am going to go with that. But what you mentioned about fuel is something that I can watch for with the 15 as well.
Thanks again,
Bob
Thanks again,
Bob
#103
AK
Howdy Gents. I picked up a purple one at the swap meet a few weeks ago.It had the os .15 la . She flew good. The frist landing tore off the landing gear. After the fix.I made up a set of wire landing gear and put a O.S 0.020 FS on her. I had to put the battery in the tail to balance. I took her up today. I love it. I've had this engin for about 15 years and this is the frist time its been in a plane. I did most of the flying at 1/2 throtle. Hkbii.
#105
AK
Howdy gents. OOPS to many 0. It should read 0.20. It came out befor the .26. im not shure but I think its the same engin its was bored and stroked to bring it to the .26 dis. It is a sweet running engin. hkbii.
