.15 engines
#52
RE: .15 engines
Jeffie8696,
Can you do me a favour please. Can you measure and advise the distance from the front of the drive-hub to the front end of the crankshaft.
Alan W
Alan W
#55
MD
RE: .15 engines
Let me guess... it's going on a Herr Lil Extra?
I ended up hscking, er, um fabricating one out of a piece of aluminum plate that I had laying around. I think the thickness was around 3/16" and I was able to re-use the original screws - I probably spent way too much time on it, but I couldn't bring myself to spending the $12 that Tower wants for one... just the principal of the thing, ya know? Oh, FWIW, I used nothing more than a cordless drill, a sharpie, and a file.
http://www3.towerhobbies.com/cgi-bin...?&I=LXCA84&P=7
Pay no attention to the results of the botched inverted harrier attempt... [X(]
Hope this helps,
-Joe
Hope this helps,
-Joe
#56
RE: .15 engines
From talking to my combat buddies, the Magnum XLS is a lot stronger than the old XL. I have an XL and it is OK power wise but it seemed like just a slight upgrade from my old OS FP. I have heard the XLS is close to the OS CVA. I have a CVA and it is a good engine. I really like the carb but I do not know if it is worth the money.
The great thing about this size of engine, there are a ton available with greatly varying degrees of performance. It really comes down to how much money you want to spend. For super hot performance, seek out the Profi, Fora, Nelson engines. I also have some Cox Conquest .15s as well.
It seems right now for the money, the Magnum XLS maybe the way to go for a hot setup, while an LA would be more sport. I think it really comes down to your objectives and the amount of money you have.
#58
RE: .15 engines
Dave, I got a nice XLS 15. it runs really sweet on 20% nitro. There is an XLS 15 category in the user reviews now. I posted my results there.
#59
AL
RE: .15 engines
ORIGINAL: OzMo
OS LA15
The SSC combat guys have "gone to" this engine for years. It Is a tough lil bugger and parts are easy to come by. the hard corp combaters run fp15 metal backplates and separate needlevalves. The tricks to get em fine tuned are *seal the backplate well * alittle extra high temp blue sealant at the carb O ring * 20% nitro got em up to 17500 rpm without modification on the required 8/3 MA prop.
Ihave 3 left over from combat flying and will keep 'em kuz I likes 'em![8D]
OS LA15
I also agree with OzMo on the OS LA15. The SSC guys swear by them. Here's a few links that might help you, if you decide to go with the OS LA15...
http://www.georgiacombat.com/OS15EngineSetUp.htm
http://my.att.net/p/s/community.dll?...pid=276092&ck=
http://www.treneffrc.com/default.asp
http://www.treneffrc.com/products.asp?cat=26
http://www3.towerhobbies.com/cgi-bin...4&I=LXCF83&P=K
Byron
#61
RE: .15 engines
The SSC combat engines are restricted by the rules. they can only go so fast and 17,500 with the prop they are required to use really is not very impressive to me. It works for what they are doing but those engines really do not have the ponies that other engines have. the Magnum XLS actually has too much power for SSC and to some degree has to be de-tuned to be compliant with the rules.
#63
RE: .15 engines
I don't know from first hand experience, but something tells me that a Fora or Cyclon .15 would fall flat on it's face if you try to run them with 8x3s. The .049-.061 versions become very ordinary if you try to run them with sport sized props.
If I'm wrong, I'd like to know just how well they can turn a 8x3, 7x4, 7x5, etc.?
#64
RE: .15 engines
I think it may be difficult to compare a longer stroke engine like the old FP and the LA engines compared to the high performance .15's that are meant to rev. They all have their power band in a certain RPM range and you do need to prop accordingly. But none of these engines need a pipe to perform, so they may be a little less sensative to prop load than they would be otherwise.
#65
RE: .15 engines
VG, the only Cyclon .15s I've seen come with that stubby silencer in back. Is that meant to give a boost? It looks too small to be there for more power and it sure doesn't seem to help much with the blown eardrums! One of these days I'd like to get one. I've got other "must haves" that need to be either blown up or worn out first.
I was just entering the hobby when .15 pylon was fizzling out, so I've never seen any of that stuff in the air. I'll bet a hot little 3/4 scale DD with a Cyclon .15 would seem every bit as fast as a .32 powered bigger brother?
#67
RE: .15 engines
ORIGINAL: combatpigg
#68
RE: .15 engines
The straight exhaust of the formula one engines did not add performance other than zero restriction. The 1\4 wave mufflers on the modern q-500 and q-40 engines do when propped correctly. That was one of the magical things about the Nelson at first. FAI racing still use full wave pipes for performance boost as well.
Many of the FAI .15 CL combat engines actually have a rubber muffler for durability. Still not really doing anything other than being legal.
#69
RE: .15 engines
Some of the Open A rc combat guys use the Cyclon .15s too.....I've got no idea which prop they use to haul those 5-6 foot combat wings around with. Word is that they have an edge over the sport engine powered wings, but not as much as some would think.
I think it would be a real kick in the shorts to have a screaming .15 set up on a speed plane. My piped CVA falls a little bit short of the mark. One of these days I'll set it up like my piped K&B 6.5 just to see what it's got.
#70
RE: .15 engines
I would bet the cyclones are running props in the 6" - 6.5" range. Maybe 7". That is just really too small to effectively pull a big combat ship around. If you could build one light it would perform but then it would not survive.
Maybe get a hold of a CL speed pan and build your plane around that. Something more for the extreme speed forum.
Regaurdless, .15 is a wonderful size and probably has the broadest performance range of any displacement.
#72
WI
RE: .15 engines
F2d engines (profi's and cyclon .15's) usually turn a 6" or slightly larger prop. They will turn a 7x3 nicely. I use them for Speed Limit (80mph) control line combat with a 7x3 prop. They are bullet proof and I love them. I do not think they would turn an 8x3 as they are timed for high RPM.
The muffler does nothing. It was a way to specify a standard exaust outlet. They have a venturi restrictor also. Some guys are flying speed with profi's
Consider the mvvs .15 only about 60 new at hobby club.
#73
RE: .15 engines
Hi Uliner, a couple local guys [Jeff Rein and Ken Burdick] are promoting 80 mph with Magnum .15s. They've got Henry N. working his magic on one of those $80 specials to see if they can come up with a low cost alternative to the more expensive motors. According to these guys, 80 mph with .15s is real easy on equipment.
#74
RE: .15 engines
#75
RE: .15 engines
I believe they are flying with 60 x .015 lines. The light planes supposedly tougher than heavier .25-.40 sized planes....less kinetic energy. Jeff and Ken would most likely be flying home made foamies. I could get you in touch with Jeff if you want more info.
