duratrax vendetta sc tire opions
FL
RE: duratrax vendetta sc tire opions
If you want an SC type if tire then I believe stock is your only option. The DTX 12mm wheel hex's will allow you to bolt on many others, but all I know for sure that will fit are on-road tires. I have also seen Vendetta ST tires mounted on a SC.
FL
New to hobbie. My kids gave me a Vendetta SC for father day. I am hook on the hobbies. I need to raise the truck higher. I am looking for something of a monster look. I also need to know what gears I need to change to kept it at the same speed. I will keep the same motor until I get better than will go brusless. Any after market part. Thanks for any help.
