1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
ezrun brushless motor .....HELP!!
Reply
Old 02-05-2011, 05:31 PM
ohlott
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ezrun brushless motor .....HELP!!
I have a ezrun brushless combo that I got new..hooked it up today to a tamtech frog...and the wires from the engine started to get really hot and smoke. Why? Running 1600 mah battery with traxxs connectors.
Thanks for the help/
ohlott is offline
Old 02-05-2011, 06:04 PM
The_Shark
The_Shark's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ezrun brushless motor .....HELP!!
.. maybe you have the power plugged into the trigger line or something (not real familiar in the naming) the two outside wires are swappable, however the center wire must be mated with the correct wire (the center wire) hopefully its still useable, but smoke is usually fatal.
The_Shark is offline
Old 02-05-2011, 06:44 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
pics of the setup would help rule out a wiring issue
Chances are either the setup was too high KV for the RC. Smaller BL motors are usually EXTREMELY high in KV rating, and need to be geared very low.
Or you wired it wrong. Almost want to doubt this one seeing I swore all the lower amperage EZ-runs are pre-wired.
Or you got a bad setup. Lets face it bad ones do get through (and before anyone says SEE CHEAP I've heard of way more castle products bursting into flames than HW)
SyCo_VeNoM is offline
Old 02-05-2011, 07:39 PM
ohlott
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are a few pictures...also the motor is a 7800kv with a 18t gear.
ID:	1559182   Click image for larger version
ID:	1559183   Click image for larger version
ID:	1559184   Click image for larger version
ohlott is offline
Old 02-05-2011, 08:19 PM
rubber_junkie
rubber_junkie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I feel you've overgeared it, how long a run had?
rubber_junkie is offline
Old 02-05-2011, 08:24 PM
ohlott
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just ran it for a few seconds and the motor wires got really hot and started to melt the casing off. So I shold use a lower gear? What size?
thanks
ohlott is offline
Old 02-05-2011, 08:28 PM
rubber_junkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if just few sec's an that happened something binding in tranmission and/or mesh to tight?
Old 02-06-2011, 05:58 PM
ohlott
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Found the problem the screws that hold the motor on were a tad to long and were hitting the coil inside the motor. Put some spacers on the screws and good to go.
thanks for all your help.
ohlott is offline
Old 02-07-2011, 04:53 PM
rubber_junkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nice 1!
Old 02-13-2011, 04:37 PM
studysession
Moderator
studysession's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: rubber_junkie
That is my first guess as well. I don't think the gearing is to high if all it was couple of sec's.
studysession is offline
studysession
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ohlott
Glad you got it working.
Reply
Display Modes
