losi micro crawler / Traxxas TX
WA
RE: losi micro crawler / Traxxas TX
ORIGINAL: gokemidoro
Not sure.
I think it's for owners of Spektrum transmitters.
Not sure.
It sits on the shelf, collecting dust, now. It's a paperweight, nothing more.
BTW, I have a micro crawler, and it's electronics went ''dead in the water'' (or ''dead on the rocks'', in this case) after only 1/2 an hour of total drive time. It was not used in a manner outside it's intended use, and was not modified. I would consider another model, as the LMC isn't reliable enough. I'm not the only one who has had this problem, either. Losi's mini crawler is a tank, as is it's comp crawler, so the fragility of the micro's electronics is a problem.
[/quote]
.. ... .. That is not good to hear.... Anyone know any other options for around that size? ... looking for something at work to mess around with
[/quote]
BTW, I have a micro crawler, and it's electronicswent "dead in the water" (or "dead on the rocks", in this case) after only 1/2 an hour of total drive time. It was not used in a manner outside it's intended use, and was not modified. I would consider another model, as the LMC isn't reliable enough. I'm not the only one who has had this problem, either. Losi's mini crawler is a tank, as is it's comp crawler, so the fragility of the micro's electronicsis a problem.
Not sure.
Not sure.
