crt.5 questions???
CA
crt.5 questions???
well the price of a new crt.5 kit at amain is down to $179.00 so im planning on getting one. i was thinking about the .12 picco red dot but decided on the dynamite .12re w/ slide carb because of the prices, any thoughts? the description of the dynamite .12re dosent specify which clutch set-up(flywheel, bell, shoes, springs)to use. which or where could i find the right set-up for the dynamite .12 re w/ slide carb? last can i use regular size servos w/out the longer chassis upgrade? thats it. thanx, 1cougar1
RE: crt.5 questions???
forget amain when can get pro version @ [link=http://cgi.ebay.co.uk/Jammin-34970-CRT-5-PRO-Mini-Nitro-Competition-Truggy_W0QQitemZ300531768374QQcategoryZ34061QQcmdZ ViewItemQQ_trksidZp4340.m263QQ_trkparmsZalgo%3DDLS L%252BSIC%26its%3DI%26itu%3DUCI%252BIA%252BUA%252B IEW%252BFICS%252BUFI%252BDDSIC%26otn%3D8%26pmod%3D 300503331673%252B300503331673%26po%3D%26ps%3D63%26 clkid%3D7575803051525740753]half price[/link]
then can get engine after (kit includes flywheel,clutch an clutchbell but be better with 16t )
mine is orignal short chassis but i use regular 1/10 servos, i just had to drill couple holes for post use for servo.
the crt.5 pro kit is supplied with flywheel,clutch,cluchbell, pipe. So its your choice of engine,servos,radio to use. Engine with SG crank required.
