1/16 revo build
1/16 revo build
This is my 1/16 revo build.I used a 5200kv motor from gotogorc.com and cheap hobbyking 100a esc with programing card.The esc is big but fits with little overhang.It has a spectrum dx3c radio.The hobbyking esc really woke this engine up and runs very cool thanks to the oversize fan.It will accept 2s-4s lipo.I run 2 2s 2200ma 40cin series with no problem.It is overkill on power this way so i usually just run them paralell for long run time which is still overkill on power.It has gpm steel axles all through.These axles are heavy and definetly help tame some of the power when running lipos.The weight also helps keep it planted on the ground for fewer rollovers.Just be sure and keep the pins in these axles tight.
