Official HPI Savage Flux XS thread...
#3051
RE: Official HPI Savage Flux XS thread...
I think this may have been discussed before, but is there a way to run cooler temps on these motors? I did make a small cut in the faux battery box the motor sits in, and that has helped a bit. But I'm looking to cool it down even further. Thanks,
#3052
ORIGINAL: gdiddy13
#3053
ORIGINAL: gdiddy13
#3054
ORIGINAL: t9dragon
Run a fan on the motor.
ORIGINAL: gdiddy13
I believe they are talking about fans for the ESC, in the previous posts a few back
#3055
You can use the fan for the castle sidewinder sct system, but personally I do;t see how it would fit without seriously modding the fake battery box near the motor.
#3056
ORIGINAL: gdiddy13
Have any pics on how this is done? Type of fan etc?
ORIGINAL: t9dragon
ORIGINAL: gdiddy13
#3057
Hey folks, new to the forum, and the hobby. My g/f bought me a savage XS recently, and I'm just having problem after problem. The first one she bought me, the ESC fried after 1 pack (turnigy 5800, 30c, 2s). Since it was only a few days after purchase, Amazon allowed us to return it. The second one ran for about 10 packs, then after a couple days, I put a fresh pack in, and it immediately started shuttering and not moving anywhere. Then smoke poured out of the ESC. There's number 2. So I realize that I'll probably never get a decent ECS from HPI, so I buy a Mamba Max Pro on the recommendation of basically everybody on the internet.
Now the fun begins. I ran it for about half a pack, and I notice it is cutting out every so often. Like, if I'm in a turn, the wheels will lock in that position but I lose control of the steering and throttle. Then it comes back after about a second. This isn't after an impact, just randomly while driving on flat cement. So I go to switch it off, and nearly burned my hand on the battery leads. I let it cool for a bit, and remove the body, and the shrink wrap on the battery leads has melted off. The next day I run it, hoping it was just breaking in or something (wishful thinking), and now the battery leads are fine, but the motor leads are getting hot. Not as hot as the battery leads did before. But still hot, and the motor is CRAZY hot (too hot to touch). Also, it is still cutting out.
Also, I'm not sure if this is related, but when I'm running the car at high speed, and then slide out, the car seems to cut out as well, but in a different way. When this happens, I lose control of the throttle for about a second, but I can still control the steering. Please help as I'm driving myself crazy trying to figure this out.
Btw, aside from the ESC, the car is stock. Any thoughts? Thanks.
#3058
ORIGINAL: digijohnson
Now for the cutting out issue... I believe this is because you need a BEC, or an external BEC. This is so the ESC can supply enough voltage to the steering servo. Someone will chime in ifI am incorrect, but i'm pretty sure that's the issue. They are cheap, but its because HPI didn;t design the Mamba Max with a good BEC
Battery leads...are you doing speed runs? that will get temps up on the motor and leads, but mostly the motor. A lot of people run fans on the motor. I don;t personally, but some people just have had heat issue and some haven't. It's wierd.
Im running a 25c battery 2s lipo. The higher the C rating, the more punch it will have. So the power will get to the motor quicker, probably creating higher temps.
#3059
Just got a new body fitted from a New Bright Dodge Ram. It was my dads from the early 90's lol. pretty sweet looking, although the battery box is in possibility of breaking i guess
#3060
well after my first esc was bad in my XS making my motor run at 190f on 2s with v-groove street tires. i sent it in got a new one after 2 weeks of waiting this was 2 weeks ago. then today i was shocked [X(] to see a fedex truck pull up with another new vapor pro esc. As i just replaced the stock motor with a 3800kv castle one guess i can make my evader brushless now
#3062
The XS SS uses wt 40.....maybe it's the same on the RTR....or you could change all the oil of the shocks for new one...
#3064
Ouch t9. Easy fixes tho! and not too costly. I had a pretty good bash this weekend. Out in the backyard was tearing it up. It flipped so stupidly, and cracked the rear hub carrier at the bottom where the pin goes thru, but it hasn't let go yet. gonna glue. then i was hauling as* at full throttle across a cut grass field, hit the driveway, bounced up about 3 feet, flipped for maybe 15 feet, hit a tree and bounced off into 3ft tall grass and weeds. drove right out of that one with no broken parts. my esc didnt like speed runs that day. i saw some milky looking liquid stuff in the esc. not sure what it was. but it turned to liquid lol. haven't tried to see if it still works yet.
#3065
ORIGINAL: cumminspower5.9
My 3rd XS should be here Friday. Not sure if I will use this one for parts or send the ESC in and than resell it or give it to my 6yr old daughter to drive...
#3066
Man you really love the XS don't ya? i wish i had more than one rc. Im going to be honest, I dont get a lot of time to run mine much. I work a lot of hours and then come home and watch my kids, so t me the truck seems stupid just sitting there, but when i get it out after a while, it remends me that this thing was built to be fast and built to be beaten. by that point i have a nice grin lol
#3067
So for at least the next couple of months I will finally have some bashing time... O, I also work 2 jobs in around everything else... But RC's are a great stress releiver... and I have about 25 RC's at this time too..
#3068
Wow, I don't know how you keep it together day by day. But yes, watching an rc fly by at high speed and then hit a jump and flip is a great stress reliever. till something breaks lol. then it sucks
#3069
#3070
ORIGINAL: t9dragon
My 11yr old son asked me this the last time we went bashing and he broke the shock. He said, "Dad can I still drive it even though it is broke.." He doesn't care if it is broke or not he loves bashing his XS..
#3071
ORIGINAL: t9dragon
I feel your pain.. I really don't have much time either to run my RC's. I have 7 kids.......
#3072
ORIGINAL: rologti
OMG....Are you a millionare????....i don't know how is in USA, but here a kid really costs money..well, it could cost almost 0, but public health, public schools, etc....are rubbish....i can't speak too much...I have just one doughter and she is 15 days old...and i'm really sleepy
ORIGINAL: t9dragon
#3073
LOL yea living here isn't too expensive. You just have to budget it. Im the only one working in my family. My wife watches our 2 year old, and we have one on the way. try living off $450 a week. its a challenge, but doable if you budget and do things smart lol
#3074
BTW...someone with knowledge about batteries and brushless conversions???....just make a brushless conversion and have some questions...
The winter is getting here....some rain and cold....RC fun is ending....
Time to get my hands into my car?....
Off topic mode: off
Off topic mode: off
#3075
ORIGINAL: rologti
Off topic mode: off
Off topic mode: off
