1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Official HPI Savage Flux XS thread...
Reply
Old 09-13-2012, 06:32 AM
  #3226
cumminspower5.9
cumminspower5.9's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Official HPI Savage Flux XS thread...
Quote:
ORIGINAL: wyumez
Has anyone found a permanent fix for our drive cup problem? I've read reports of the HR drive cups breaking as well.
Ha! Run it with a NiMH battery. Either that or JBweld the dogbones into the drivecups. The biggest issue to failing drivecups is the slop. If the slop can be taken care of, it should fix the problem. Either that or CVD's will take care of it. With the pins on the dogbones not fitting tight into the cup, it allows them to "snap" to seat itself to get power to the wheels. Overtime, it leave indents in the cup and weakens it.
cumminspower5.9 is offline
Old 09-13-2012, 08:43 AM
  #3227
Thiagooo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: cumminspower5.9
Quote:
ORIGINAL: wyumez
The cupjoint of hotracing breaks?
Mine arrived this week ... still not installed '-'
Only solution is to spend JB? Durepox? But it will be very rigid ...
Thiagooo is offline
Old 09-13-2012, 08:59 AM
  #3228
cumminspower5.9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Thiagooo
Quote:
ORIGINAL: wyumez
I haven't tried the HotRacing cups, but I have heard in several instances that they can break also. JB weld or permanently fixing them to the cups will work. But it will be difficult to JB weld the cups coming out of the transmission. My diff cups are still perfect. Its the 4 outer cups, center cups, and the cups that go to the diffs are the ones that wear. I'm sure there are other ways to fix them, but the main thing to do is to stop the dogbone from moving in the cups. Shims, foam, something. See the picture. If you stop the pins from doing this to the cups, problem solved. Doesn't matter how you do it tho.
Old 09-13-2012, 09:02 AM
  #3229
cumminspower5.9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Thiagooo
Anyone know what this noise might be?
I opened that box and everything ok ta ... also open that part smaller, and everything is right with the gears, but doing this weird noise ...
This is the rear differential.
The front works without noise.
This Dogbones without connecting to the engine, I also pulled the engine ... finally. this light and loose.
[youtube]8phhJy8N1lo[/youtube]
http://www.youtube.com/watch?v=8phhJy8N1lo
Pull the diff apart. I didn't watch the video, but if anyhting makes a noice that's not natural, pull it apart. Mine makes a clicking sound. So I took the rear diff apart and found a missing tooth on the ring/bevel gear.
Old 09-13-2012, 11:59 AM
  #3230
wyumez
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Thiagooo
Quote:
ORIGINAL: wyumez
Ha! Run it with a NiMH battery. Either that or JB weld the dogbones into the drivecups. The biggest issue to failing drivecups is the slop. If the slop can be taken care of, it should fix the problem. Either that or CVD's will take care of it. With the pins on the dogbones not fitting tight into the cup, it allows them to ''snap'' to seat itself to get power to the wheels. Overtime, it leave indents in the cup and weakens it.
Here is a [link=http://www.msuk-forum.co.uk/topic/140201-smash-savage-xs-build/]link[/link] with a Savage xs build that had problems with the HR cups. I think I'm stubborn and loyal to the Savage, which is why I won't give up on it yet!!!
Hrmm.. I wonder if I can try fuel tubing, or even a hard play-dough like putty I can use to prevent the dogbones from rubbing... silly putty lolz.
I'll search around for a compatible part later on tonight. There MUST be a high-end truggy such as a Kyosho or Mugen drive cup we can use instead.
wyumez is offline
Old 09-13-2012, 12:24 PM
  #3231
cumminspower5.9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: wyumez
Quote:
ORIGINAL: Thiagooo
Quote:
ORIGINAL: wyumez
Ha! Run it with a NiMH battery. Either that or JBweld the dogbones into the drivecups. The biggest issue to failing drivecups is the slop. If the slop can be taken care of, it should fix the problem. Either that or CVD's will take care of it. With the pins on the dogbones not fitting tight into the cup, it allows them to ''snap'' to seat itself to get power to the wheels. Overtime, it leave indents in the cup and weakens it.
Well you can either buy expensive drive cups (which for a high end one might cost you) or just shove some kind of good in the cup and jam dogbone in it and put it all back together. Silly putty might not be a bad idea. use something maliable that wont come off inside the cup at high rpms.
Old 09-14-2012, 05:02 AM
  #3232
wyumez
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: wyumez
Quote:
ORIGINAL: Thiagooo
Quote:
ORIGINAL: wyumez
What would be great is if we had a drive cup that looked like this:
wyumez is offline
Old 09-14-2012, 05:17 AM
  #3233
cumminspower5.9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yea that definitely looks more sturdy than the stock cups. The stock cups split too due to the slot for the pins. HPI should just make CVD's for the XS and it will solve everyones problem for the diff and axle cups. now the center cups would need a new design.
Old 09-14-2012, 11:10 AM
  #3234
sparky 25
sparky 25's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Those cups in the picture are stock hpi Baja cups with a hardened steel band slid over them,
My xs cups don't even look used yet and being the ss it's has cvd's at the wheels,
If the cups are breaking on the xs, an after market company would make some easy money providing cups with the steel bands in place.
sparky 25 is offline
Old 09-14-2012, 11:25 AM
  #3235
cumminspower5.9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sparky 25
If they had those cups for the output of the tranny, and made cvd's for the inner and outer axles, i would definitely spend the money
Old 09-24-2012, 11:20 AM
  #3236
Thiagooo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone know if there is good tire masher 2.2 on savage xs? Or is it too heavy?
About gear, 24T and 60T decreasing to help?
As stated here: http://www.prolinera...s-xs-flux-mini/
Thiagooo is offline
Old 09-25-2012, 11:29 AM
  #3237
spena
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys finally back home (toronto) after 3 months in kansas for work. Ive been out of the loop since then but is there anyway to increase ground clearnace on the xs? I need more height when I bash during the winter to avoid snow build up.
Edit: noticed an odd noise on my xs and though it was coming from the gear box but i think is from the wear on the drive cups:
ill order those HR Hardened drivecups but how I remove the drive cups? Ialready removed the screwshafts but the drivecups wont budge
spena is offline
Old 09-26-2012, 03:02 AM
  #3238
Thiagooo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Remove the screws from cupjoints and then pull them out. Simple as that.
one that has a spring clutch, needs more strength ... Last time I opened I used a screwdriver to move it out
Thiagooo is offline
Old 09-26-2012, 07:11 AM
  #3239
spena
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Thiagooo
ahh i see, I should have put wd40 on it and let it set overnight
spena is offline
Old 09-26-2012, 09:58 AM
  #3240
spena
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
upon setting my order for the HR hardened centre cups I realize ive been negalecting my xs since built my stampede 4x4 with mmp+3800kv, teknos all around etc.
This is my list so far to strengthen my lil xs, let me know if need to add anything else:
HPI Universal Drive shaft set instead of HR hardened centre cups
Alum. heat sink Motor Plate
Jeep Wrangler Rubicon Body HPI106704 (thinking white/black tone)
CC3800KV motor
Current hopups: Powerstroke shocks, tbone bumpers, traxxas turnbuckle mod, traxxas servo, geolander+hpi wheels
spena is offline
Old 09-26-2012, 03:00 PM
  #3241
Thiagooo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You have geolander yokohama? Are really good?
Quote:
ORIGINAL: spena
CC3800KV motor
Thiagooo is offline
Old 09-27-2012, 06:04 AM
  #3242
spena
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
@Thiagooo
Yea the geolander's are great! prob the best tireslistedin the Option Parts list on the HPI website.
I was hesitant before buying since I wanted to order the Mashers 2.2 or the Dirt Hawgs but I didnt want to wait for it to ship and the geos were in stock at my lhs.
Its great on grass, pavement and dirt but not so well in snow. Had the tire for a year with little wear after 25+ runs on 2S
spena is offline
Old 09-27-2012, 11:10 AM
  #3243
Thiagooo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hmmm... thanks
Well, I really wanted was a masher, but many say it is too heavy for the transmission and the ESC.
Or buy the dirt hawg II or yokohama, however yookohama is smaller than the stock ...
Thiagooo is offline
Old 09-28-2012, 05:31 AM
  #3244
spena
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Thiagooo
hmmm... thanks
mashers will be my next set after I put in cc 3800kv and the universal driveshafts
spena is offline
Old 09-28-2012, 06:14 AM
  #3245
Thiagooo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The masher is very pretty haha, just afraid of having problems with the ESC and transmission ...
The gears stock are: Crown 56T and 28T PINION.
 If I put a crown 60T  and 28T pinion... What will change? what will change in relation to the stock 56T?
Because I wanted to buy only the 60T CROWN HOTRACING, but wanted to know what changes over 56T, running with the same pinion ...
Thiagooo is offline
Old 09-29-2012, 03:39 PM
  #3246
spena
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
still having trouble removing my drive cups ib the center transmissionscrewshaft has been removed)
really want to avoid buying a new center transmisson..
spena is offline
Old 09-30-2012, 01:07 AM
  #3247
sparky 25
sparky 25's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You haven't even removed the grub screws on each drivecup,
Remove the grub screws and then the worn cups will come off the transmission
Old 09-30-2012, 10:13 AM
  #3248
spena
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sparky 25
yupp its been removed prior to attempting to take out the cups.
its suppose to just come off or do i need to twist it off? I see some rust could that affect it? i also tried putting wd40 and soak it for the night and still wont move.
edit
finally was able to take it out. took two adults to take those cups out lol
hopefully the universal driveshafts would do better than the cups
spena is offline
Old 09-30-2012, 05:30 PM
  #3249
pubmaster861
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow those cups are ready to go!!!! Lol how many runs you got on them? I'm asking cuz I want to pick up one of these trucks
pubmaster861 is offline
Old 10-01-2012, 04:07 AM
  #3250
cumminspower5.9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well for the first time since I have owned the XS, I pulled apart the transmission to inspect and clean it. The slipper pad has been completely torn to shreds but remained in the transmission in a powdery form lol. It was totally gone, but it still wad enough material left on the hub to grip lol. Crazy. Now the diagram in the manual seems to show 2 slipper pads. Mine only had one. Correct me if I am wrong.
Reply
Display Modes
