1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Official HPI Savage Flux XS thread...
Reply
Old 09-20-2011, 07:39 AM
  #451
Spaz163
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Official HPI Savage Flux XS thread...
Quote:
ORIGINAL: cooper998
four packs through and it flamed up! was running 3s Venom 5000 20c pack and motor and esc were getting very hot. Talked with the guys at the lhs and they suggested gearing down but did not have a smaller pinion at the time. My guess is HPI geared it to run 65mph so it could claim the top speed and would try to correct issues as they surfaced.
Unfortunately we suffer as guinea pigs while they get their act together, which I am sure they will.
Anyone know of a reliable esc I can use while I wait for a replacement? Will the Sidewinder Sv2 be good enough?
coop
I believe you are right, I think they geared it crazy high just so they could claim the high speeds. Therefore, the motor is drawing high amps and frying an ESC that can't handle the current draw. Now here is the question... do we go ahead and gear down and try to fix a problem that we shouldn't have to fix?
Spaz163 is offline
Old 09-20-2011, 08:01 AM
  #452
srt10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does HPI show the amp specs on this stock esc?
Thanks....
srt10 is offline
Old 09-20-2011, 08:42 AM
  #453
Foxy
Moderator
Foxy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I highly doubt it since castle does not.
To other posters... It will not do 65mph out of the box, not even on 3s. The manual describes the gearing needed. The box stock speed on 3s is about 52 mph if i remember correctly.
Foxy is offline
Old 09-20-2011, 08:46 AM
  #454
Foxy
Moderator
Foxy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Coop, the stock ESC is a sidewinder v2 according to what I've been reading. If that's the case, it is considered to be around a 60A esc, though castle will not confirm it. If it is though, it should be adequate for most needs at this scale. I'm wondering if something they;ve done to it before giving it to HPI for this car, has somehow affected it adversely. If you want to be safe, I'd go for a Mamba Max Pro, and while I'm at it, I'd get a sensored motor too. Then I'd ebay the stock pieces.
Foxy is offline
Old 09-20-2011, 08:50 AM
  #455
Peloche
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all,
I'm new to this forum and i do appreciate all your informations.
I'm very sorry for those having problem with burnt ESC.
I started RC with a car that never worked more than 5 min in a raw, I've spent money for spare parts and gave up, then I went for HPI E-Firestorm 10T Flux (105879), it's gorgeous, I keep it.
My first question is about the availability of this Savage XS, I'm in Europe and it's only pre-order, but it's the same for TowerHobbies, so where did you get yours from ?
I placed a pre-order for XS almost one month ago, but after reading all breakdown reports here, i'm a bit upset and it makes me wonder if i should change my order.
Thanks for your advices,
Peloche,
Peloche is offline
Old 09-20-2011, 08:58 AM
  #456
RCJuice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I must admit that I'm glad that I waited to get my XS, these are the types of issues that I prefer being sorted out before buying a new model.  I had bought the Revo when it first came out (I think back in '04) and told myself I'd never buy a first-run again.
I still can't wait to get mine though!!
RCJuice is offline
Old 09-20-2011, 09:05 AM
  #457
t9dragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most of the issues happening with the ESC are when using 3s lipos.
t9dragon is offline
Old 09-20-2011, 10:04 AM
  #458
chopan84
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so i shouldnt have a problem running a 5450mah 2s lipo?? will it still do standing backflips on 2s?
chopan84 is offline
Old 09-20-2011, 10:16 AM
  #459
t9dragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: chopan84
You probably won't get standing backflips on 2s. You can try tightening the slipper clutch down all the way and see if that works. I was doing my standing backflips using 3s but I also wasn't doing any speed runs either.
t9dragon is offline
Old 09-20-2011, 10:24 AM
  #460
nitro-rob
nitro-rob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am guessing a manufacturing problem and a bad batch. If these ESCs are blowing this easily it must be that because they certainly wouldn't have missed such an obvious problem in testing.
Unfortunately, returning ESCs is likely going to lead to the same problem since they likely don't have a new batch.  They probably had a bunch of truck shipped and a stack of spare ESCs which are from the same batch that they are giving people in the meantime knowing they are the same and likely to blow.
I think high C-rated batteries may help.  For the people whose trucks didn't blow up, what was the C-rating?  I ask because the charge and discharge cycling of the caps in the ESC will get hot and blow if the batteries can't supply what the ESC needs (ie. they don't like to work out of phase) so its not hard to believe if the motor is pushing the ESC to its limit that the batteries could be heating the caps too much if they aren't a high c-rating.
Should I just get it over with and blow my ESC when I get it and go on to the MMAx pro?
On an unrelated note I am in India right now and have been using my crawler in some amazing arrangements.  If I didn't have a wonderful family I would throw away my return ticket (and have my XS and other RCs mailed here).
nitro-rob is offline
Old 09-20-2011, 10:40 AM
  #461
t9dragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So in going back thru the thread I have found that between 8-10 esc's have gone up in smoke and that is almost split evenly on it happening with 2s and 3s lipos with "C" ratingsof 20 all the way to 50.
Like a couple of other people have said there must have been a bad bunch of ESC's.
t9dragon is offline
Old 09-20-2011, 10:44 AM
  #462
Foxy
Moderator
Foxy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Peloche
Hi all,
Peloche,
I wouldn't worry too much, there are still alot of people that have had no problems, though the frequency does seem to be surprisingly high. I still plan to order one soon whether they solve this issue or not.
Foxy is offline
Old 09-20-2011, 10:45 AM
  #463
Foxy
Moderator
Foxy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: t9dragon
So in going back thru the thread I have found that between 8-10 esc's have gone up in smoke and that is almost split evenly on it happening with 2s and 3s lipos with ''C'' ratingsof 20 all the way to 50.
I agree. What concerns me though, is that in at least one case, a replacement that has been sent out has failed identically. That would indicate that HPI themselves are unable to identify the bad ones. This must be hurting Castle with so many returns.
Foxy is offline
Old 09-20-2011, 12:20 PM
  #464
redfisher1974
redfisher1974's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Peloche
Hi all,
Peloche,
You should check out the official E-firestorm thread here, Full of good info and good people who love the storm.
redfisher1974 is offline
Old 09-20-2011, 06:38 PM
  #465
nitrohawker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Those of you sending your stuff in to HPI....did you have to pay shipping?
nitrohawker is offline
Old 09-20-2011, 06:39 PM
  #466
nitrohawker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hobbytown here told me they had one right out of the box go up in smoke first time they they pulled the trigger.
Old 09-20-2011, 06:45 PM
  #467
t9dragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: nitrohawker
It all depends.. I had to pay shipping there and they paid to send it back to me.
t9dragon is offline
Old 09-20-2011, 08:53 PM
  #468
dcfever
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
they told me they will send out a replacement next week from new shipment. not sure if they meant another batch?!
by the way, is there any upgrade service from hpi? like I just add money to get a replacement of Mamba Max Pro instead?
dcfever is offline
Old 09-20-2011, 10:08 PM
  #469
Peloche
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi dcfever,
HPI Savage XS ESC stock is Flux Vapor, on HPI site they propose as option part 2 ESC:
One is Bullet ESC standard and the second one is Flux 2350 standard.
ID:	1664975   Click image for larger version
Peloche is offline
Old 09-20-2011, 10:25 PM
  #470
Foxy
Moderator
Foxy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: dcfever
It's definitely worth asking, the worst they can say is no. HPI's MMP is their Qbase esc stock in the Savage 2350, as noted above.
Foxy is offline
Old 09-21-2011, 05:03 AM
  #471
RCJuice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anybody know if this battery will fit? The specs are right but I'm not sure about the cables coming from the center instead of the side of the battery. I don't have my XS yet but am trying to line up some batteries for when it does get here.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
What do you guys think about starting a separate thread just for batteries so we can get a good list of what does and doesn't fit? I've followed this thread from day one and there is some good battery info in heres, but it's getting long enough that it's becoming a little tedious to sort through and find the info I am looking for.
RCJuice is offline
Old 09-21-2011, 09:31 AM
  #472
t9dragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Johnbalz
From looking at the measurements for the battery box and the ones for the battery you are asking about it would be a tight fit. It is better to have the wires coming from the top of the battery than the side for the XS.
Here are the measurements for the battery compartment.. 143mm x 47mm x 31mm
t9dragon is offline
Old 09-21-2011, 01:45 PM
  #473
RCJuice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: t9dragon
Quote:
ORIGINAL: Johnbalz
Thanks. Yeah, I figured the battery itself would fit based on the battery box size, but since I don't have my XS yet I wasn't sure about the wires coming from the center versus the side like most packs. I'm still not sure what packs to buy. I'd like to pick up a couple 2S and a couple 3S packs.
RCJuice is offline
Old 09-21-2011, 01:47 PM
  #474
t9dragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Johnbalz
There are several Venom 2s and 3s that would fit.
t9dragon is offline
Old 09-22-2011, 10:26 AM
  #475
nitro-rob
nitro-rob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine just cleared customs today after being there for eight days. Looks like it will arrive in the next day or two.  I plan on removing the 'bomb' right away.  I am considering calling HPI saying I know of the multiple ESC fires and am not interested in trying considering the precedent for these things to go up in smoke.   I don't like the idea of subjecting myself to the nerves of wondering if or when its going to go.  If they ask me to start a fire to see if I am warranty eligible I will find that funny.
Reply
Display Modes
