HPI Savage XS Flux directional Stability
My new XS has a bad directional stability.
When driving straight it reacts extremly nervous and it is nearly impossible to drive a straight line.
In the manual I could not find anything regarding the topic.
The front tires are nearly parallel, and have hardly any angle towards each other....
Is there anything I can improve or adjust?
Thx for help.
Regards
Andi
p.s.: The car ist still completely stock
Thx for help.
Regards
Andi
RE: HPI Savage XS Flux directional Stability
Because the car is a "mini", it has a small or short wheel base. this combined with the power and torque makes it hard to control under heavy throttle. if you are running the stock tires, upgrade them. this will be the best upgrade for that. I am running proline badlands on HPI monster ss rims right now. i have no problems going in a straight line under heavy throttle. and they are excellent on grass and any other surface. they don't wear quickly either. get those tires and you will see a drastic difference in handling.
Yeah - I realized already that the stock tires to not have a good grip - neither on dry nor (even worse) on wet track...
And this car is really incdredible fast. I use 2s Lipos 4000 mAh 30C.
Thanks for the suggested tire - rim - combination.
I will have a look for that.
What will I have to spent for a complete set?
regards
Andi
regards
Andi
Sounds reasonable...
Thanks for that information.
I will have a look at them and check whether I can get them here in Germany...
Regards
Andi
Regards
Andi
