Where to get steel pinion and spur for Sumo RC?
I'm having trouble finding steel spur for my Sumo RC. I already found an 8t Steel Pinion. I checked AtomicRC and they have steel spurs that might work. Does anyone know where I can find a 34t Steel Spur? or does it matter how many teeth it has?
See if you can put the pinion on the spur shaft if so you can get a 30-40 steel pinion and use that for a spur.
you may have to custom mod it to fit because im not sure how it locks in place pin-slots etc but I doubt they purposely made steel ones for them been low powered.
