1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Help with servo pulling
Reply
Old 11-15-2014, 09:32 PM
katzcratch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Help with servo pulling
I have a c18 team assoc. the car was pulling one direction to the point i had the throttle trim all the way turned. I figured i would replace the servo. after installing and uninstalling I am still stumped. When I install the server everything is neutral and the servo connection is straight. when I get it all attached and try it it turns easily both directions, but when I release one directions won't return the wheels to straight. it goes partially back but not to center. so incase i am not clear if i was to turn right the wheels turn, and then stay partially turned, something is binding and I can't figure it..any advice?
thanks
katzcratch is offline
Old 11-15-2014, 10:28 PM
collector1231
Moderator
collector1231's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check for missing screws on the steering bellcrank. That is what normally causes it. If you don't see or hear anything like this, a new servo is in order. Luckily, Atomik RC's having an early Black Friday and all servos are 30-50% off!
http://www.atomikrc.com/collections/...gh-speed-servo
collector1231 is offline
