1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
electrix ruckus questions
Reply
Old 02-23-2015, 09:05 AM
jeff_83
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default electrix ruckus questions
So just bought the ruckus 1/18th and would like to upgrade to a bigger battery and maybe a brushless motor. What are u guys using? Thanks
jeff_83 is offline
Old 03-03-2015, 03:03 PM
collector1231
Moderator
collector1231's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a drop-in brushless combo that will make it go really fast. This is a LiPO battery that should fit and work well with it.
Now, all you need is a Deans connector and LiPO charger, if you don't have one already.
collector1231 is offline
Old 03-03-2015, 03:05 PM
jeff_83
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
K will look into it thanks
jeff_83 is offline
Old 03-11-2015, 06:30 AM
earthdogjim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just bought and installed a Hobbywing quicrun 16bl30 along with a 4300kv motor and changed out the receiver to an Axial radio and bigger tires/rims.
The little truck is fun now and hauls butt.
ID:	2080628   Click image for larger version
ID:	2080629   Click image for larger version
earthdogjim is offline
Old 03-13-2015, 08:52 PM
collector1231
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I see you took my tire advice well, Jim. Lol
Old 03-14-2015, 07:11 AM
earthdogjim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Which advice was that, Collector?
Old 03-14-2015, 07:35 AM
collector1231
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That the Mini E Revo tires fit on the 1/8 Rukus.
Old 03-14-2015, 11:44 AM
earthdogjim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I got them and they look pretty good. Thanks.
Old 03-27-2015, 05:52 PM
jeff_83
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What about better shocks? Just blew one shock cant screw the cap back on.
jeff_83 is offline
Old 03-29-2015, 06:37 AM
earthdogjim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Measure the shocks and look on Ebay, I found 4 aluminum shocks for $18
Old 03-29-2015, 06:42 AM
jeff_83
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ya i seen some that said will fit and ordered them up. Whats a better rim and tire? Maybe a little bigger for ground clearance and what did u guys do to make them work? Not looking to drop alot, put in a brushless motor.
jeff_83 is offline
Old 03-29-2015, 07:52 PM
collector1231
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Traxxas Mini E Revo tires/wheels are a direct fit and look good.
Old 03-30-2015, 08:23 AM
jeff_83
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jeff_83 is offline
Old 03-31-2015, 04:53 PM
jeff_83
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Would the traxxas 1/10 rally tires be to big? Found a nice set on amazon for 35.00
jeff_83 is offline
Old 04-04-2015, 09:08 PM
collector1231
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Those would be a bit too big.
Old 04-05-2015, 07:38 AM
jeff_83
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
K thought so
jeff_83 is offline
Old 04-26-2015, 02:03 PM
jeff_83
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok so i need another idea for brushless system. I bought the trackstar 7.5t 6100v and having problems with it.
jeff_83 is offline
Old 11-03-2015, 07:04 AM
Beamie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Gearing Up a 1/18 ECX RUCKUS
29OCT15 – On this dreadful dead I’ve succeeded in burning up a brand newHobbywing*EZ-RUN Brushless 2030 12T 7800Kv motor that had 4 minutes of actual usage on it before seeing the inevitable “Blue Smoke of Death.”*
I decided to install the 7800Kv motor in my*1/18 ECX Ruckus 4WD, in which I recently converted to a Brushless system, to see if I can gain a little more speed out of it over the*Turnigy*2-Pole 2040 4500Kv motor with a 16T pinion gear attached to it.*Hobbywing*had a stock size, 14T, pinion gear attached to it.
Initial speed run indicated that the two brushless motors can and did achieve identicalTop Speed*of 28 MPH in which I believe to be pretty darn good for an 18th Scale 4WD Monster Truck. My goal is to find the perfect ESC, Motor, and Gear combination that will push this lil’ MT to speeds of about 35 MPH. Is it possible, I don’t know, but I think so. Installing an ESC/Motor combo that can handle 3S battery will help me get closer to that goal.
I realize that the Power/Weight ratio exceeded what the motor could actually push with a 14T gear. The truck, with a 2S 2200 MAh 40C Zippy Battery, weighed in at 1.943 lbs. The smallest gear I have is a 12T pinion gear and a 62T spur gear, but seeing the temps reach 272 degrees I do not believe that the motor temps would have come down far enough to prevent the motor from burning up anyway. I probably would have gain about 2 more minutes of runtime from the motor.
Temps with the*Turnigy*motor in it ran like this:Trackstar*30A WP ESC = 75 degrees; Battery = 66 degrees; motor = 133 degrees. With theHobbywing*motor: ESC = 83 degrees; Battery = 72 degrees; motor = 272 degrees.*
The other thing is that the*HobbyWing*motor cogged with the 14T pinion gear whereas theTurnigy*cogged with the 12T pinion gear, but not with the 16T pinion gear. My guess is that the motor needed more timing with the smaller pinion gear in it. No mourning needed, just a moment of silence for a dead warrior whose time with us was much too short.*
Anyone out there know what would be the optimum motor/gear combo I should try to reach my goal or do I risk burning up another motor trying different combos? I also know that the amount of Amperage (Current) a Motor draws depends on the Weight of the Vehicle, Gearing (including Tire size and Final Gear Ratio), and RPM.
Nonetheless, In some ways it was cool seeing the lil' truck crawl to a halt, as if the battery ran out, and start smoking the way it was doing. I need to keep a fire extinguisher nearby, in case of fire, for future runs and experiments.
Beamie is offline
