Mini Monster Baja upgrades
My Feedback: (10)
Finally got around to doing some work on the mini.
Added a brushless motor, I have had it so long I forget what it is. Pretty sure its a Turnigy 2835 3900kv. Squeezed in like a sardine.
60t spur, its for a mini t but fits perfect.
Castle Sidewinder Micro.
Turnigy 1.6ah lipo, this probably had a lipo in it when it was new, but when I got bought it used there was just a cheap nimh battery with it.
Pair of new servos from hobbyking. One of the originals had stripped out (common issue). Unfortunately the replacements were slightly larger but dremelled out the chassis and made them fit. Still seems to have an issue keeping center though. I did add an aluminum GPM tie rod to help with the steering. It is crisper but still not holding center. Could just be that the servos I bought are cheap?
And replaced a broken front shock tower.
Well it flys now. Everything staying cool.
My Feedback: (10)
Found the pinion, got it all back together and running great. Until my kid comes over and says it has a problem. One of the servos is twitching like crazy; motor came loose and is missing a securing bolt; and one side of the GPM tie rod came loose, bushing gone, screw gone. GRRR The motor was rather hot, might put a fan on it when I get it all together again.
And I cant find a new set of body mounts (reasonably priced that is).
In case you didnt know, the mini monster baja is just a mini LST2 with different tires, body, and a lipo battery, so that might help when looking for parts... My mini monster baja is sitting about 8 feet from me, but is down due to broken servos.... I will fix it one day, or maybe just sell it..... The body posts are part # LOSB0912, here is a set http://www.ebay.com/itm/like/3714577...chn=ps&lpid=82
My Feedback: (10)
Thanks. I did get a set. At the time there werent any cheap ones. And i havent reassembled it yet. Bought a bigger (and hopefully better) servo to go with just one instead of the pair. But like I said, nothing is installed. Coaching two soccer teams leaves no time for my rcs. But season over in a week and a half!
