1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Tires
Reply
Old 07-24-2015, 05:35 PM
Luexor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Tires
Can I put 2.8 inch tires on a merv. I'd prefer the dirt hawgs by proline
Luexor is offline
Old 07-24-2015, 10:17 PM
collector1231
Moderator
collector1231's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, but make sure you shim the diffs correctly and get metal CVDs first. Probably not even worth it after all that, lol.
collector1231 is offline
Old 08-26-2015, 06:45 PM
bill_delong
bill_delong's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd closely monitor your temps because you'll drastically increase your final rollout. A temp gun is probably the single most important tool in helping you protect your investment. Let the temps tell you how to gear your car with the following general limits:
Battery < 120
ESC < 140
Motor < 160
*** check the user manual for specific limits to the equipment you are using, the recommendations here are conservative limits to ensure your equipment last a reasonable amount of time.
Here is the temp gun that I like to use:
http://www.harborfreight.com/non-con...ter-93983.html
hot battery = replace with higher C rated pack
hot motor + cool ESC = under geared
hot ESC + cool motor = over geared
hot everything = WAY over geared
Start with your stock gearing and then go from there... also keep in mind that driving surface conditions, tires, worn bearings etc all effect your temps... always check your temps just like a 1:1 car has a temp gauge to tell you the overall health of your system.
Remember, a temp gun is the single most important tool to own in this hobby. If you have the money to upgrade your electronics, tires, etc, then you should also include the cost for a temp gun without a doubt
bill_delong is offline
