1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Dromida dt 4.18 brushless.
Reply
Old 08-09-2015, 09:09 PM
ricksol91
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dromida dt 4.18 brushless.
Hello, I am fairly new to the rc world, So I decided to get a Dromida dt 4.18 brushless from my local hobby store to get myself into the hobby. I have had it for over a month now and have only had to replace minor things thus far. Anyway today I was driving it around on my street I noticed when I start would give it full throttle it would start making a really loud high pitched screech. The only way I can think of how to explain it is like nails on a chalk board, So I went online looking for a new motor and besides the stock 5300kv motor it comes with I came across an Xfly 5300kv brushless motor for half the price. Can I use that? Also what are my other nimh battery options can I get a 1600 mah instead of the 1300s?. Thanks in advance.
ricksol91 is offline
Old 08-11-2015, 05:53 PM
suburban_hooligan
suburban_hooligan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i don't know if the brushless motor has bearings or bushings, but lube them. see if that squeak doesn't go away.
unless something is wrong (gear mesh to tight, over geared, etc) a brushless motor shouldn't go bad in a month.
and yes, you can upgrade to a higher mah battery no problem. and, im not 100% (haven't really checked out the brushless versions yet) but i think you can even run a lipo battery.
suburban_hooligan is offline
Old 08-12-2015, 12:25 AM
ricksol91
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great, thank your for the information.
Old 08-12-2015, 03:18 AM
flyinwalenda
flyinwalenda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have yet to hear of a brushless motor failure on these yet due to normal conditions. As mentioned try a few drops of light machine oil on both ends of the motor shaft.
Also check the pinion to spur gear mesh and check the grub screw on the spur is tight.
The brushless vehicles will take a lipo pack and that really makes them move !
flyinwalenda is offline
