Wltoys A979 1/18 2.4G for under $60 bucks!! with lipo! video inside!!!
Got this lil beast and its an awesome truck!! check it out!! did a review on it!
Wltoys A979: http://goo.gl/xRcxw2
Wltoys A979 Gears: http://goo.gl/Xwt2Xp
https://www.youtube.com/watch?v=kv5vXkiGZ5E
Wltoys A979 1/18 2.4G 4WD 50km/h high speed monster RC racing truck can be played on ground, grass land and sand land
With independent shockproof system, it can prevent damages caused by the vibration effectively
Rubber wheels prevent slippery
Adopt the high toughness explosion - proof PVC shell
Independent suspension frame system, effectively reduce the friction causing from the vibration
Powerful motor, maximum speed is up to 50 km/h
Wheelbase: 95mm
Wheel diameter: 71mm
Wheel width: 40 mm
Motor: 390
Transmitter frequency: 2.4G
Speed: 50Km/H
Servo: 17g
Battery for truck: 7.4V1100MAH
Running time: About 10 min
Charging time: 150mins
Control distance: More than 100m
Truck battery: 7.4V 1100mAh LiPo
http://des.gearbest.com/uploads/2015...1334038993.jpg
http://des.gearbest.com/uploads/2015...1334024545.jpg
Wheelbase: 95mm
Wheel width: 40 mm
Motor: 390
Speed: 50Km/H
Servo: 17g
