1/35 Orlandoo Hunter AH35P01 and AH35A01
Orlandoo Hunter
Taizhou Orlando Hunt Model Technology Co., Ltd
http://oh-model.com/
since 2012
AH35P01 (ford F-150 Raptor)
Vehicle Length: 170mm
Vehicle Width: 70mm
Height: 63mm
Wheelbase: 116mm
AH35A01 (Jeep Wrangler)
Vehicle Length: 126mm
Vehicle Width: 57mm
Height: 63mm
Wheelbase: 50mmmm
ESC
MOTOR
1. DC6V 24000RPM±5% 1:298 80RPM
2. DC6V 12000RPM±5% 1:100 120RPM
3. DC6V 15000RPM±5% 1:100 150RPM
4. DC6V 20000RPM±5% 1:100 200RPM
5. DC6V 15000RPM±5% 1:50 300RPM
DIFF
Orlandoo F150 stock gearset
crown:25t pinion:13t
Ratio 1.92:1
Orlandoo F150 V1 Brass/metal gearset
crown:20t pinion:12t
Ratio 1.67:1
Orlandoo F150 V2 umbrella Brass/metal gearset
crown:25t pinion:14t
Ratio 1.78:1
Orlandoo Jeep/Alloy diff kit
crown:16t pinion:8t
Ratio 2:1
GEARBOX
Orlandoo F150 Gearbox
pinion 19t
idler 19t
output gear 19t
Ratio 1:1
Orlando Jeep Gearbox
pinion 19t
output gear 19t
Ratio 1:1
incomplete.... need sleep check back later
since 2012
Vehicle Width: 70mm
Height: 63mm
Wheelbase: 116mm
Vehicle Width: 57mm
Height: 63mm
Wheelbase: 50mmmm
ESC
MOTOR
DIFF
Ratio 1.92:1
Ratio 1.67:1
Ratio 1.78:1
crown:16t pinion:8t
Ratio 2:1
GEARBOX
pinion 19t
idler 19t
output gear 19t
Ratio 1:1
pinion 19t
output gear 19t
Ratio 1:1
