Dromadia Short Course Truck wheel sticking problems
The small diameter of the inside of the wheel let's rocks get stuck in the wheel locking it up what size wheels can I go up to to fix this problem
I would look for a bash spot that doesn't have the size of gravel that gets stuck. I would be very careful going to a larger wheel size, as you will increase the overall gearing, making the motor run hotter. If you do this , find a smaller pinion gear to compensate. You don't want your motor to get over 170F.
