Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > 1/16th, 1/18th, Mini & Micro RC Cars
Reload this Page >
What's that battery connector on a 7.2v battery pack for a 1/8 desert truck called?
1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Old 11-17-2017, 08:14 PM
DadSonsAndToys
Default What's that battery connector on a 7.2v battery pack for a 1/18 desert truck called?
On my Losi 1/18 Mini-Desert Truck, the stock battery is a 7.2v NiMh battery pack with small connectors. I need some more of these connectors, male and female. Anyone know the official name of these connectors?
ID:	2245436Click image for larger version
ID:	2245437Click image for larger version
ID:	2245438Click image for larger version
ID:	2245439Click image for larger version
ID:	2245440Click image for larger version
ID:	2245441Click image for larger version
ID:	2245442Click image for larger version
Last edited by DadSonsAndToys; 11-18-2017 at 10:49 AM. Reason: Wrong scale in title
Old 11-18-2017, 03:09 PM
FlapJackFred
FlapJackFred's Avatar
I've always called them HPI/Losi mini connectors. If you type that in (Losi mini connectors) a search, you'll get lots of places to go to.
https://www.ebay.com/sch/i.html?_nkw...tery+connector
Old 11-18-2017, 10:33 PM
vinmansbrew
Huh, I'll try this again, since my previous post disappeared.
If you are going to be having to already change connectors on packs, get good connectors. Those are not very efficient, better than the old tamiya junkers from the 80s, but still not good. Get a quality plug like deans. I mean, if you already have to solder, you may as well use something good so more juice gets to the motor instead of being wasted from inefficiency.
Old 11-19-2017, 08:52 AM
FlapJackFred
True ^^^, but dealing with 18awg wire on battery packs probably.
Old 11-19-2017, 05:26 PM
DadSonsAndToys
I agree, but I'm not soldering or changing any battery connectors. This little 1/18 doesn't draw enough power to make any difference in the power connectors. I'm just making an adapter for my charger.
I despise Deans for RC. Not for their efficiency or quality, but for how hard they are to work and play with. Tricky to solder, need shrink wrap, hard to connect and re-connect, I'm over them. I was all Deans when I first got started in RC about 10 years ago, but after much research have decided to switch to Anderson Power Poles. I have a bag of Deans, Traxxas, EC3, XT60 connectors and have very little use for them now. APP are the Cadillac of RC connectors, IMHO. No soldering, and it's just so very sweet with the speed of crimping connectors and still having a better connection than soldered joints. There are many other advantages of APP compared to the other connectors available. I use the 45 Amp APP for 1/8 and 30 Amp APP for everything else.
Oh, I used a Dean connector the other day for an LED work light extension cord that I built. Dean was best because of their low profile (no snag points) and because it will rarely be unplugged.
Old 11-20-2017, 08:24 AM
RustyUs
RustyUs's Avatar
You have a bag of Deans, I had a bag of Anderson Power Poles (I just got rid of them) .
I used APPs and Deans from '91 to present day. Only have to sets of APP connectors for Power Wheels batteries now, and swapped out all my Deans T-Plugs, and EC5 connectors with XT60 connectors. A big THANK YOU to the creator (Amass) of the most perfect connector. IMO of course .
Old 11-20-2017, 09:37 AM
DadSonsAndToys
I used APPs and Deans from '91 to present day. .
What didn't you like about APPs?
Old 11-22-2017, 10:41 AM
RustyUs
RustyUs's Avatar
The size is what killed it (APPs) for me. Not to mention prying/pulling the contacts out was too much for me . Seriously, it was the whole clunkiness look/size to the Anderson Power Poles. Deans T-Plugs were too small, but I put up with them (far too long). Heck, I even used Deans mini/micro 4 pin connectors for my motor connectors before the T-Plugs came about . I feel I get a better contact patch by using something with tubes. I like the EC3/EC5 concept, but having to insert the male/female contacts is just dumb. The XT60 connector combines the look, size, and easy solder-ability into one fine connector.
Old 11-26-2017, 10:07 PM
DadSonsAndToys
The XT60's look nice, I've used them the least. I think I missed their popularity on my RC hiatus. Imitation Anderson Power Poles just outright suck. Authentic ones snap in pretty nicely for me. I agree, they are a pain to pull off. I don't usually pull them off to reuse them, I just cut them off and start over. I put up with the clunkiness of the APPs because of the ease of working with and their scale-ability (the same connection housing fits 15, 30 and 45 amp connectors).
Old 11-27-2017, 01:52 PM
vinmansbrew
Connectors are a personal preference, but if you think a 1/18th doesn't pull enough power, you'd be wrong. On my dromida, I swapped the plugs because they got warm. Warm = wasted power. Kinda like the old crappy tamiya connectors from the 80s that are STILL found. I chose deans long ago because of their virtual zero loss. I know others are as good today, but honestly, I don't mind soldering and heatshrink. Either connector you choose, you never go wrong by putting on a better one.
