1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
NEU 1110/1y vs Castle motors 1/16 E Revo?
Reply
Old 09-13-2019, 09:38 AM
iKayo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default NEU 1110/1y vs Castle motors 1/16 E Revo?
Hey everyone!
Can anyone recommend the NEU 1110/1Y vs the Castle Creations motors? For an ESC I am going with either the Mamba Max Pro or Mamba X.
The problem with the stock 380 is that it gets very hot, especially while using Lipo batteries. And I wanted to run a single 3s battery for good speed and torque. I have been reading a lot on the forums about these motors but these are posts from years ago.
I was hoping somebody could chime in and inform me of what is the current "best of the best" setup scenario in terms of a motor/ESC combo to date. Technology always gets better over time and from reading old posts it seems like the Castle motors or NEU motors were king.
iKayo is offline
Old 09-23-2019, 06:55 AM
seedygreenute
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I cant comment on those motors as I have not used them .
You are right , the stock motor does run a bit hot . A fan or heat sink will help a little .
Cutting out the windscreen and fitting mesh will help airflow over the motor .
One of the biggest problems with these is the lack of space to fit bigger / better ESC .
The Mamba X is way too big . The Mamba Max I have seen fitted but it sticks out from the chassis . Also seen it fitted inside the battery tray but you need to cut a big square hole for the fan to fit . You also lose a battery tray if you do it this way .
Hope this helps .
seedygreenute is offline
Old 10-07-2019, 07:50 AM
zedorda
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found a wonderful combo on the cheap for my MERV(big block) that actually performs well. A GoolRC motor from amazon for $20USD and a spare SW3 SCT esc. I had to give up 1 battery bay to the esc but it handles 3s real well.
The motor pictured: https://www.amazon.com/gp/product/B01DBS3MQQ/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
EDIT: I still haven't had to shim the diffs yet but it does have the bulkhead with the cross screw.
zedorda is offline
