Official Mini-T Thread
#1702
RE: Official Mini-T Thread
Upgraded the Baja motor yesterday, and now I have a glitch of some sort. Can anyone tell me if a solder can give power sometime and not at others? Or if my stock electronics cannot handle the upgrade. Very strange. It speeds off just fine, then it will just stop for no reason.
any advice,
thnx
any advice,
thnx
#1703
IL
any advice,
thnx
any advice,
thnx
The stock ESC should be able to handle the BAJA motor .
#1704
okay, turned the brushes upside down(no real up or down) and now I have constant connection. That is good news! The bad news is the heat sinks got super hot the first run and it stopped running. A cool down period and it is good to go again. I took off the body and it runs just fine. Any reason it would get that hot? Also, what is the stock esc capable of handling? Someone told me 16t, but I can't find it in manual. And what turn is the baja, 18t?
thanks again
thanks again
#1705
NJ
whats a good brushed motor for a stock mini t? i have a good battery. but iv always had nitro cars and my brother just got a mini t and it could use a little more power. we are also gonna buy bearings so yeah. i might also race it on a pretty tight track so what would be good?
#1706
I suggest the Team Orion Super Charged 1600 mah. I got it when I first got the mini-t and it is makes a difference. Especially if you upgrade the motor.
#1711
NY
Frozen72: As long as the tire is the same size as your dish rims, you can use any tire of the same size....... So Look around. I use Proline Dirthawgs they seem to perform very well on offroad/onroad/and basically all terrain. The tires are very durable too and they last a long time
N.rustlerfreak
N.rustlerfreak
#1712
NY
Frozen- The team Losi Smasher Tires would be great for all terrain use. The best part is you can buy them premounted from Losi.
#1714
NY
It is a good motor with no maintenance but the performance will not be as great as the Trinity Cobalt 18 or the Reedy Mini Max. But overall it is very efficent. For specs on the motor check out:
http://www.one18th.com/MotorSpecs.php
#1715
NY
My b/l Mini-T is finally together again... with carbon chassis and a bunch of other alluminum stuff.... All is have to do is install the servo and program the esc to my transmitter. I seem to be having trouble programming the mamba to my controller.. hopefully ill get it going soon
N.rustlerfreak
N.rustlerfreak
#1716
I might get my Mini-T running it just depends on if my more favored cars are running good and I don't want to get any more upgrades for them.
#1717
CA
ok, I have an 18T but have an idea for placing a mini t tranny in it for a CD and slipper, anyone got a link to a COMPLETE diff, and if i want to go brushless with it, are there any mods I have to do to it[8D], thanks
#1718
Thats a really cool idea! I wonder which batteries you'd run? would be a funky config....maybe not. Would have to see it layed out. Keep us posted.
#1719
NY
Calvino- are you taking about the Diff for the Mini T Tranny or the RC18T. If you are talking about the mini T then heres the link:
http://losi.com/Search/Default.aspx?...%20Ball%20Diff
#1720
NY
YES! I just got my mamba brushless to sync up with my controller. I took it for a test drive with my 7 cell battery and this thing wails!! Maybe ill put a vid up
N.rustlerfreak
N.rustlerfreak
#1721
NJ
pretty beat. i ordered bearings and a motor on the 3rd and for the motor the seller has only sent usps electronic shipping info and for the bearings i havent gotten any shipping info at all
#1723
IL
I'm looking to race a little carpet with my Mini-Baja. I am going to get rear foams from Losi and a lexan gear cover with the slipper cap thing, so I can adjust the slipper without taking the gear cover and wheel off. Is there anything I should know or anything else I should get? Thanks
Pontiac K
Pontiac K
#1725
FL
Hey Everyone,
I need some advise on some batteries for my kid's Mini-Ts.
Right now we are running them on 4 sets of 4 rechargeable 2500mah AA batteries. I have 4 chargers going but we are not getting more than 10 mins of run time per set of batteries. It is getting to be a PITA.
I need to buy 4 battery packs and a charger so they can have longer run times and they need to be rather inexpensive.
I don't want to blow $25 per battery if i have to buy 4 of them.
Rob
Rob
