Official Mini-T Thread
#2176
RE: Official Mini-T Thread
ORIGINAL: JPerrone
ESC for Mini Baja with Lipo:
I am taking the lipo plunge but I have read somewhere that the standard ESC does not protect the battery during low voltage, ie, a different ESC is needed.
What are good replacements for this? I am not a racer, more a "casual basher". But I do appreciate quality.
Regards
Regards
i think the esc in the baja has a low voltage protector. i only say this because of how fast the car will go from full bore to dead stop when the battery gets lower. or is that just how nimh batteries work?
#2177
Banned
ORIGINAL: toymdngn
ORIGINAL: JPerrone
Regards
Regards
U CAN GET LOW VOLTAGE CUTOFF FROM NOVAK
#2180
ORIGINAL: Alex73
Just ordered a mamba 6800 and mamba micro pro esc.
I cant wait to get it.
can anyone tell me if these brushless systems are reversing? i only use mine for around the house and bashing ouside, and i use reverse ALOT. i just want to make sure i can back out of the hole i'm in when i get into one.
#2183
NY
Alex73- Let us know how the mambe pro esc works. I am looknig at that set-up for my racer but i want to see the specs from castle first (They still haven't released the specs yet[&o])
#2184
I broke my 4th servo holddown. I'm going to get one in alloy next time I'm at the track. Maybe if I had that would help also...
#2185
Banned
ORIGINAL: Deftones123
dying the chrome losi rims with rid dye wont work, works only with the white or yellow ones, unless you take off the chrome with stove cleaner.
YOU CAN DYE ANYTHING
EVEN CHROME RIMS
#2186
Banned
ORIGINAL: toymdngn
ORIGINAL: Alex73
#2189
I have dyed the losi yellow and white rims with rite dye and they worked perfect, but when dying the losi chrome rims it doesnt work
#2197
I've had HORRIBLE luck with Integy. The track owner it going to give me a great deal on it. Hopefully I'll be able to start putting some money in to my Rustler vs. my Mini-T since it's been running good for a while minus the brace. What mamba system is just a slight bit faster then the Orion Baja? I was thinking the 5400 or 6800. I'm going to get a 4200 motor for $20 so I'll have a motor for REALLY small tracks.
#2198
the 6800kv is crazy fast on full power, if I was you I would get the 6800kv and when you want to run on the track put it on lower power, just incase you want the extra speed one day to do speed runs and such
#2199
I have had my integy brace for a month and it hasnt broke or bent and I beat the hell out of my mini t, rolling it oging like 40mph and such
