Chassis for rs4 micro
RE: Chassis for rs4 micro
i like the penguin 3500lm chassis. replaceable rollplates, removable baterry plates, vcs shock ready, and looks sharp too. they have 4 versions. the narrow p3500, p3500lm, p3500el(it is a 3500lm meets arm low cost high features), and the new p3500rs. the rs is the newest requires high end small electronics to fit.
penguinrc.com it there site, and if you order a p3500lm through radmicrosport.com you get free shopping and two rad bodies.
peter
peter
ORIGINAL: Project_2501
after the chassis what is required for a ground up build-up? aside from motor, batt, esc, rx/tx?
bearing kit(team orion/rpm)
front bulk heads (stock/alloy)
rear diff ball/gear (hpi)
knuckles (team orion/top/gpm)
belt hpi only
wheels/tires
wheel hubs or one peice alloy rims
you could alwasy go to one18th.com people are blowinng out hoped up micros and m-18s.
but it is fun to build one out of parts. i know i missed something. see if you can download the manuel from hpi. will have a complete parts list.
good luck
peter
My Feedback: (12)
ND
the 3500lm does look nice for sure...Gives more placement options for racing...dont suppose you have one?Im curious what the center battery mount is.....i assume same as what the normal is but i wanted to make sure.also curious about mini servos over the use of standard..
Joey
Joey
the LM comes with a new center battery mount. it is a a peice of g10 fiber glass you glue/tape/velcro the battery to. it is held to the chassis by two screws. and yes i do own both the 3500, and the 3500lm.
peter
peter
