mini t big block motor
IL
hi, im wondering where i can get a big block motor thats pretty cheap. i found someone online that said in another forum that he got his from a website that sold it for $15.00 does anyone know what website sells this for dirt cheap?
RE: mini t big block motor
well what motor is it i paid about $10 for a big block 300 the otherday when my stock pakcet up but i havnt used it its looks quite impressive abouty 16k rpm, i would have to recomend the scorpian motor for just another $10 mine come yesterday and it is amazing i build a ramp and from a stand still i can clear about 3/4 feet other than that look on ebay
PA
i would look at teh rabid motor from blindbatts.com it is a dyno'd 370 and its 25 bucks....supposedly very fast from what i hear and i will be geting one when i get both of my mini-t's and some more money lol....
Take a good look at the Beast motor from one18th.com It's supposed to be one of the best out there. You can run the stock electronics with it. I'm using a big block right now, it runs good with 7.2v but when I use 8.4v it gets really hot! I know it probably just my gearing but...
Hope that helps.
Hope that helps.
PA
i run a wattage 370 its Fast enough and Cheap! like 10 bucks at a hobby shop that sell planes. I ran a graunper for 3 months of heavy use!! and it on took everything like a champ. they are great motors and you cant beat the bang for you buck.
IL
wattage 370's are good, as they are the motors that the rabid and diamond 3 are based on, just that they are tuned. Brain, running the wattage 370, you notice good run times and speed?
PA
The wattage 370 thus far i've had about 10 runs or so. Really nothing yet. But its great thus far. The run time is at least up in the 40 min range. I'm running a kan 7.2 pack that im getting like 1200mah out of every charge. I bought one of those expensive modded 370's. Honestly its slower than my 370. I'm not impressed by it and it wasnt worth the extra 15 bucks.
WA
ORIGINAL: 2Slow2Go
do any of u guys have radio interference after installing the new motors? if so, what radio r u using? thanks
Matt
