spur problem
spur problem
Hi guys
took my mini-t out 2day for a little run and i had a death rattle so i packed it back up inot the boot of my car, when i got home took the gear cover off and could see nothing wrong with the meshing so i held down throttle and held the spur gear[:@] bunrt all my finger
anyhow i noticed that my spur gear isnt revolutioning perfect so i took the slipper off and found a loead of melted plastic on the spur but the slipper itself looks fine ??
what have i done wrong[]
i am probabily going to order the 3 racers spur and pinion pack but if some 1 could let me know what i did so i dont do it again i would be gretfull
RE: spur problem
thats nuts, i know the spur gear is plastic on plastic, so when it gets warm it will probably get soft eventualy melt, I would get a mip slipper or racer's edge they are metal slippers. Sorta make it more bullet proof. I know I am going to get one in the near future, I will probably order one w/ the mip cvds.
RE: spur problem
dang, well i just ordered me the team losi/MIP cvds, and a racer's edge slipper.
I also have the MIP ball differential on the way.
I am looking at getting lunsford Ti hinge pins and turn buckles, I wish rpm made the ball cups for the mini t.
PA
RE: spur problem
yeah a better slipper would help. I've been running the racers edge one for a while and love it. If the hole in the spur gear still looks like a circle i would say you just need a new slipper or vice versa. A new slipper clutch is a worthwhile hop-up
RE: spur problem
yeah im going to get an upgraded slipper and replament spur 2morro the t is running but i dont wana jump it hard because and kill the gear box,
im conidering doing a full gearbox upgrade, ball diff, swingshafts, slipper and spur then i should see some improvemnt but im not sure weather to just get the slipper and get used to setting it up
by the way my finger looks mean as hell
RE: spur problem
nice i just got my mip differential, and rpm bumper from RCboyz. Ordered the MIP cvds, and slipper set, should be in the end of the week or so. Love those guys service they are the greatest.
