mamba pinion gear
mamba pinion gear
on the mamba BL motors, is it correct to assume that the pinion gears that are made for hpi's rs4 and duratrax's micro street force will work on the mamba?
which brand do yall run with- hpi, duratrax, orion, etc?
my stock gearing is 14/60. on the 6800kv motor, is it better to retain this ratio for backyard bashing? i remember someone mentioned to have the spur at 61.
if changing ratios, is it better to keep one gear the same and only change the other or is it better to change both gears from stock settings?
thanks
thanks
