Mini-T reciever troubles
My mini-t has been running great for as long as ive had it and had great range and all but just recently my range has been limited to about 100 ft. The batteries are fine, the antenna on the reciever is not damaged and the antenna on the transmiter is screwed in all the way. i have no clue what is wrong and if anybody has the answer to my question it would be appreciated
PA
RE: Mini-T reciever troubles
honestly the losi esc/reciever is junk. run it as long as you can but sooner or later its gonna give out and you gonna have to replace you electronics. if the car is still under warrenty call up horizon hobby/losi and see what they will do for you
AZ
if you are going to get something besides stock and not spend as much will be a novak micro spy speed control a jr radio and reciver xr2i would be good or any one you want a hitec hs85 and a team losi servo saver and a motor depents on you hope that helps
