MAMBA Brushless Motor Thread!
#502
RE: MAMBA Brushless Motor Thread!
cant i use the stock reciever/servo for the time being???
p.s which would be better to get mini-t or RS4???
(i just want a low maitenance super fast car)
#504
Hi guys.. Long thread[8D] Winters almost here so time to forget about 80 mph gas riggers.
I didnt see anyone ask about how this Mamba CM2080 would fit & run in the soon to be released Associated RC18T so I will.
Any Ideas?
Second. I will be running either a Mini T or the Associated RC18T on a small carpet track with plywood jumps. I see allot of comments stateing the Mamba 8000KV is to much for small tracks. Are there any alternatives to the 8000KV motor which would make the car faster on a small track (better cornering)? Like the Chili Pepper CP20L Series? Or other high power combos which weigh less than the mamba?
I dont need to run 50+ mph. I want the fastest lap times though.
Any Ideas?
Well there are 4 different motor set-ups...........and all are available from AlleRc...........
This link is the 4 motors
[link]http://www.allerc.com/index.php?cPath=7_52[/link]
And this is the set-ups and how different they are
[link]http://www.allerc.com/Pictures/MambaSetups.pdf[/link]
Hope That Helps
Hope That Helps
#506
Man how is going to be the one to put 3 Lipoly in with the Mamba 8000.Iam uning 3 lipoly in my Mini T whit the Mamba 5400 and its fast.But I think Iam going to get the 8000 soon and put 3 in it.
#507
Well im so happy cause my Mamba 8000 just came today so im trying to fit it now and ive only been in from work for 10mins
#511
so guys y can't i compare the RS4 and the mini-t???
i just want a vehicle with top speed so which would be faster with the mamba 8000???
p.s is it possible 4 me to use stock radio equipment with the mamba???
#513
NO you cannot use the stock mini-t radio equipment u need a seperate receiver setup..
and i said not to compare them because one is a 2 wheel drive stadium truck the other is a 4 wheel drive onroad car.. but if u want just speed go with the rs4... for speed and jumps go with the mini-t
#514
ok irish_GS_Sonic
Thanx very much for all ur help
i'm gonna get the rs4!
i'm gonna use my savage radio but which reciever can i use that will work with the mamba???(please post a link from tower)
p.s will this reciever work:
http://www2.towerhobbies.com/cgi-bin...?&I=LXALL0&P=7
#515
ok irish_GS_Sonic
#517
Can anyone give me any ideas why after seting up my mamba 8000 i have NO power in reverse...........i have FULL power forwards and FULL BRAKE but NO reverse.[]
Shaun
I set it up at first for the calibration and skipped the rest and set the brake with the PC link to 50%
#520
Hmm - try it at 100% and see what happens. Might be a bug in our beta Mamba-Link USB software.
What batts/connector do you use?
Shawn
Shawn
#522
Well set @ 100% i now have reverse but i would say its 25% power.............but there are serious glitches forward and reverse
#523
PA
ORIGINAL: Richie-EB4
I haven't played with it much since this morning but I will on Monday... If you figure it out please let me know... G
#524
AZ
if you get the rs4 rtr then you dont have to get any thing cause it is all seperate but if you want toa mamba in a mini-t the you need seperate esc and reciver
#525
yea shawn i member in a difrent forum i told you about when u sent me the beta software and using it not holding the settings for me.. but i have long got over it and everything is good. wonder what is doing it.
