building a ramp
building a ramp
im going to be building a small mini track in my basement for me mini t and im looking to make a ramp so i go more straight up then i do go far. so what im asking is since i dont have much wood available is like card board. will a stock mini t be able to move it around or will it be fine? and any other ideas would are welcome.
my idea for the track is since its really long is that it will be a oval but im going to take cardboard which i have alot of is bend it alot and use plenty of duct tape to hold it down and have a bunch of doubles. then for the ramp im going to jump my couch(SP) then land on pillows then keep going from there. and have more doubles and other stuff.
but the main point is how to build a ramp out of cardboard. Any one ever try i really cant use wood like i said.
RE: building a ramp
Since the Losi Mini-T ships with a cardboard jump, why don't you use that as an example and simply change the angle so you can go more straight up than farther out?
RE: building a ramp
It's not that big and I actually never used it since I'm either jumping off of dirt or wooden jumps. I've actually jumped my Kyosho Mini-Z-Monsters off of higher jumps than the ramp that ships with the Losi Mini-T.
CT
RE: building a ramp
you want to build a curved ramp not an angled one because with a curved ramp you can hit it with much higher speeds and it pre-loads your shocks before the jump, with the common angle ramp you car just kind of hits it and roughly launches off it with a much higher risk of breaking something
