My MAMBA will not stop thermaling!!!
I have a mamba competition X package (mamba 8000kv, mamba 25 esc) and i bought the usb connection and i made a default settings, i updated the software, and i made sure there wasnt any physical problems (like gear mesh, something getting in the way of spur or pinion or something). I am running a 2 cell 1900 mah lipo, and after about 3 minutes the motor becomes burning hot (literally, it feels like the head of a nitro engine if youve floored it for 3 minutes) Ive also tried using 8 cell gp1100 nimhs, but i still got the same problem. Do you have an idea of what might be happening? thanks in advance.
RE: My MAMBA will not stop thermaling!!!
It depends on what rig you're running it in and what your tires are and what your gearing is. Temps around 180 F are normal, but any higher and I'd recommend you drop your pinion down a tooth or two.
