Mini LST Thread
#53
CA
RE: Mini LST Thread
this is like a super noob question but I just got my tierods for my mlst and how do I put them together, they screw type things, do they screw in or do you have to hammer them in because I cant get them to screw in
#54
MI
RE: Mini LST Thread
They screw in!! DONT HAMMER ANYTHING!!! It might be tricky at first but they will go on eventually, make sure your going the right way and apply pressure (push) while turning!!
#58
AZ
RE: Mini LST Thread
man i just took my MLST to the desert and went off some BMX dirt ramps, launchin up about 5-6 feet, not breaking a thing. I have the ball diff and the replacement losi diffs and it runs AWESOME in dirt!
#59
MI
RE: Mini LST Thread
ORIGINAL: ofnaDOMINATION!
I searched and didn't see anything on RCMart.com
#61
CT
RE: Mini LST Thread
Found them! Nice stuff, and I will DEFINITELY get their wheel adapters so I don't need to use Ebay to get CAW's. Is it based in England? If so, can they ship overseas to me? Is the shipping reasonable? Does Hot Racing make good stuff?
#62
My Feedback: (-1)
RE: Mini LST Thread
well ,guys if you don't have access to a lathe you can just get a 5/32 end mill (size of mlst wheel hex shaft)and chuck it up in a drill press or a hand drill just got to go slow steady if you do it by hand and run it inabout 1/16. i am telling you guy's it is very easy to do and you don't have to wait for shipping just go to your local lhs and go to work on you new hex's.
#65
RE: Mini LST Thread
whats up with the flimsy antenna tube??
ive broke mine like 4 times, i think im gonna put one from my xxx-nt on there. never had a problem with that one.
#66
RE: Mini LST Thread
ORIGINAL: iceracer65
didnt even bother with mine
replaced it straight away with an aftermarket jobby
#67
AL
RE: Mini LST Thread
How has everyone mounted the Kokam Cell Pro 2000 mah 3 cell li-po battery in their Mini-LST? This thing is huge. You'd have to take out the battery tray or make serious modifications to it.
#68
CT
RE: Mini LST Thread
Will the Hot Racing 1/10th scale wheel adapters work on the MLST? I think tha they're made for the MLST, so I am really asking, is it good stuff?
#70
My Feedback: (19)
CT
RE: Official Mini LST Thread
i just put the mamba and the aon bl and it is very impressive it whelies on comand only on the rug in my house theres to much snow outside and im running a 3 cell lipo very sick already fried gears in the center diferential can some let me know where i can get a spool set up thanks
#73
MI
RE: Mini LST Thread
My mlst is sooo beat up. Today I went to race it at my lhs with my new rims and I went off of the jump and the rim broke so I was going to go swap em and then I found that the nuckle was broken after that I found out the plate that holds the A arms was cracked.lol Now I need to buy a truck to drive till I get new parts.
