Mini LST
#2976
IN
RE: Mini LST
i made 2 vids so far, [link=http://www.rcuvideos.com/item/C224ZQ0S4PV01FVJ]vid 1[/link] , [link=http://www.rcuvideos.com/item/FK4YWYVHL240C2C5]vid 2[/link]
#2978
IN
RE: Mini LST
Well i got another vid... the last jump in the vid i snapped a front axle, so it now has mip cvds [link=http://www.rcuvideos.com/item/H5WFQRBT4KTMZF5G]vid 3[/link]
#2981
RE: Mini LST
ORIGINAL: rawvoodoo
Anyone have any ideas about that right rear. I am using dynamite alum arms, and stock knuckles. I have hot racing alum knuckles but they arent on.
#2983
OH
RE: Mini LST
yeah its on the hex right. Ive tried several sets of wheels/tires the only thing I havent tried is going completely stock on the arms/knuckles....why? cuz Im really stubborn. Sometime this week Im hoping my exotek lxt conversion will show up. I'm sure it will involve a complete tear-down dso I will check the all-stock setup then. As for tires, I havent been able to run it enough to wear the tires. Snow,rain,snow,snow,snowrain,rainy snow . I hate Ohio weather.
#2984
RE: Mini LST
I haven't had my MLST out in a few weeks but can't you adjust rear toe?
It looks only slightly toed in and it must be because of your tie-rod.
#2986
RE: Mini LST
Hi guys,
I've just ordered myself an mini lst2 and i hope it will arrive next week.
Now i got a few questions and i hope you can help me. At home i got quite a few 6 cell stick battery like tamiya uses, and i was wondering if there is an easy way to modify my lst so it can fit those? I've got no problem with modifying the entire truck myself, but if there is an after market part what does the trick it will be just easier.
#2987
RE: Mini LST
ORIGINAL: rawvoodoo
look at the exploded view of the mlst2 on Losi's site they went to solid knuckles in the rear...no tierod,no adjustabilty.
I never new they went to solid knuckles in the rear.. I liked mine with the linkage[&:]
#2988
RE: Mini LST
ORIGINAL: pim
Hi guys,
Hi guys,
Your going to need cells that are 2/3A in size (it comes with one, if you bought it new).. That 6 cell batt is around the size of the truck(wich uses Sub C type cells)
#2989
RE: Mini LST
and I was wondering all the time why I could only find 1000mAH/1400mAH racing packs for it instead of 2100mAH and above.
Well there a few quistion that i have and i'm hoping you can awnser them.
First of all, I'm not looking for high speeds. The car will be running in an urban setting, so speed aint that important because ther ain't no mutch space.
Battery life and good controll over lower speeds are the things i'm looking for.
Improving battery life: Should i go to Lipo pack's?
I've also heard that using a brushless motor will extend your battery life, but aren't brushless motor made for speed, speeds al lot higher that the stock car?
#2990
OH
RE: Mini LST
ORIGINAL: Dokioto
Hmm... Something is warped or bent then..
ORIGINAL: rawvoodoo
#2991
IN
RE: Mini LST
ORIGINAL: Dokioto
Not bad.. How are the tires wearing?
ORIGINAL: Haulin Azz
here is my mini lst 2 after a new body and dirt tires!!!
#2992
RE: Mini LST
ORIGINAL: pim
A nice Mamba Motor (brushless) will give you only a little more speed, but loads more torque. A 6800 would make for a descent set-up.
#2995
RE: Mini LST
Humm, i'm browsing through all the information here (a 120 pages of info are stiff reading).
Now i'm wondering what to mod in the beginning, should i go for better batteries, better motor's, better gears, and so forth.
So my intention now are to upgrade the drivetrain first, before i start upping batteries, motors, esc's.
But when i was browsing the net I couldn't find steel or hardend steel gears, only aluminium ones. Have they never made steel gears for this car? or have the aluminium gears proven to be better than the steel ones? Or am i barking up the wrong tree as usual.
#2999
RE: Mini LST
ORIGINAL: rawvoodoo
my problem turned out to be (mainly) my skull skidplates. One of them was bent up and was making my entire back end out of line.
