Mini LST
#3176
RE: Mini LST
Ah.. I haven't had a problem with them getting loose... As for being careful when you solder, a few seconds with a dremel takes care of any solder that goes to far... I guess Everyone likes different things and thats OK....I'm not trying to convert you , just wanted to hear your experience...
#3177
OR
RE: Mini LST
After having a servo go bad after only a few runs, I didn't want to spend the $40-80 to upgrade servos. The stock servos have plenty of torque, the gears just suck. I considered the metal gear mod, but that was expensive as well.
What I did, was bought a stock servo gear set, and pulled apart my good servo as well. I boiled that gear that always breaks, and put it all back together. So far, I have at least 10 runs on the servos, without any more problems. Not exactly a long term test, but they have definately lasted longer than they did without boiling. I'll update if they break again, but I have high hopes. If they fail again, I'll probably just do the metal gear mod.
#3178
RE: Mini LST
Hey guys, i just wanted to say hi! I have my 1st Mini LST comming soon. I trades one of my TT01 drifters for a new MLST. I cant wait. Any Tips? or Tricks?
#3179
RE: Mini LST
I cant really think of any tips other than dont clip a solid object with your tire at full speed, and dont run into stuff.... first think I would do, adjust your steering travel so that max servo travel doesn't strain the servos because they are pushing against the stop... servos will last longer that way and you will get more runtime (slightly)
#3180
RE: Mini LST
hey folks,
have a look at this picture and offer your opinions please. your looking a a losi insave 370 covered in metal filings and I don't know why.
#3188
RE: Mini LST
hi all.. just got a mlst2 maybe a week ago and of course, had a servo self destruct yesterday.. i was aware of the issue before and at first was trying to be gentle with it.. the problem is that this truck is too much fun! within 2 charges i was beatin on it like a red headed stepchild.. i love the way handles, very nice aerial manners.. definitely going exotek with it.. i'd like to go mamba micro pro 6800 also but i'm a bit worried about the drivetrain.. lots of options there so i'm not exactly sure how to go about upgrading that area just yet.. i have a center ball diff on the way(shipping to iraq is awful, everything takes around 2 weeks to get out here) from a previous order so that's a start.. anyone have the part number to the dual disk slipper that i hear so much about?
#3189
RE: Mini LST
ORIGINAL: bigireland
#3190
RE: Mini LST
http://www.horizonhobby.com/Products...rodID=LOSB1131
#3191
RE: Mini LST
thanks.. i'll be ordering that one soon.. unfortunately i have the losi ball diff on the way but i'll grab a MIP one as a spare.. my only remaining concerns now are f/r gearboxes and/or driveshafts.. i'm looking to make this little guy as tough as possible.. i think it's already a pretty tough truck aside from the steering and drivetrain issues.. i figure i fix those and i'll have a beastly little truck..
#3192
RE: Mini LST
MIP centre drive shafts and CVDs are the way to go as far as making in bulletproof. Not sure that the stock gearboxes need to be changed out to help your cause.
#3193
NY
RE: Mini LST
I finally pulled mine off the shelf, again. Ran it for a whole ONE pack, and lost all power. Steering still worked, the motors would still spin, but the truck wouldn't move. After some looking, I stripped the bevel gear in the front diff AGAIN(makes 6), even with it shimmed nicely. A call to Losi, and they said that they are sending out the parts that should fix this. Had the truck for almost 4 years, ran it maybe 12 packs, destroyed 6 bevel gears on the front axle, and most of the time, it's been a shelf queen due to frustration at the bevel gears. Is there anything I might have missed when going through it before? I have a MiniT Pro with brushless, and it's a blast. I just want this one reliable so that I have something I can run during lunch at work. Most I'll do for upgrades would be 2 Trinity Mini Monster brushed motors and replacement servos.
P.S. I was digging through the rest of the posts, but after page 50 it felt like my brain was melting.
#3194
IL
RE: Mini LST
Do you have a MLST or MLST2 ? The MLST diffs are pretty weak , the MLST2 diffs are better . And you must shim the MLST2's side bevel gears inside the diff cup too make them stronger .
#3195
NY
RE: Mini LST
The original Mini LST. I have 2 aftermarket ball diffs sitting here waiting, but with it eating the bevel gear that engages the ring gear, I didn't want to put any upgrade parts on it. It's just frustrating that everytime I run it, I have to replace the bevel gear. I would have expected better from Losi, especially after running the living snot out of a Mini T and seeing how well that held up.
#3196
RE: Mini LST
ah so you mean you stripped the pinion gear, not the bevel gear... the bevel gears are inside the diff, which is connected to the ring gear, the pinion is connected to the driveshaft, and turns the ring gear. Super Easy fix, upgrade to MLST2 pinion and Ring gear, they are metal.... Ive run numerous packs through my mlst2 and never had a problem, and i use a lipo....
#3197
RE: Mini LST
hey i am new to electric i bought a used mini lst2 with a lipo battery,i am getting maybe 4min of run time on it.I just wanted to know was this normal or is the battery going bad i have the mamba 6800 system installed
#3198
RE: Mini LST
well, without knowing the capacity of the battery, its hard to say, but if you are talking about the lipo the MMB came with, thats probably pretty good with hot brushless system like that in there....
