1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Mini LST
Reply
Old 05-14-2006, 02:06 PM
Dokioto
Dokioto's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Mini LST
I think I am going with the WRAITH 7K & Quark 33amp Car Pro Combo from B-P-P. Heres the link, http://www.b-p-p.com/proddetail.php?prod=db_wraith . And I can just use the stock gearing. How would you gear it?
Dokioto is offline
Old 05-14-2006, 06:48 PM
-Inverted-
-Inverted-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I havn't, I just boiled my gears, then lubricated them all with Traxxas lithium grease. A dual mamba is a waste of money, one moter will be faster then the other, and it will put load on the other motor and cause it to burn up.
-Inverted- is offline
Old 05-14-2006, 07:03 PM
Dokioto
Dokioto's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, better keep that in mind. Inverted is your mini lst running yet?
Dokioto is offline
Old 05-14-2006, 07:25 PM
-Inverted-
-Inverted-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It was for a little bit, while trying to replace a broken screw, the screw broke off so now I have to order another part. I also want to say that the stock MLST radio does NOT work well with the Quark. If you have an aftermarket radio your in the clear though.
Old 05-14-2006, 08:09 PM
Dokioto
Dokioto's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats not good. All I have is the one that came with my TC4 rtr.
Dokioto is offline
Old 05-14-2006, 09:18 PM
  #31
-Inverted-
-Inverted-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That would probably work fine. The problem is the throttle band in the stock TX is just wacko.
Old 05-15-2006, 11:32 AM
  #32
Lilredmachine
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: -Inverted-
Lots of people have run dual Mambas/Hyperions etc. with no problems. Check 1/18th.com. What does tend to happen is that the diffs disappear very quickly, the tires are extremely hard to keep on the rims and the front wheels never seem to touch the deck. With dual mamba systems, just turn down the power on the motor that gets hot, problem solved.
Incidentally the diff problem is intermittent between trucks. You get some people (like me) who have never blown a diff, and others that blow them every 2 minutes (literally). The difference is getting a perfectly formed ring and pinion from the factory and a perfectly formed diff housing that doesn't allow slop in the bearings.
Xtants MLST:
Lilredmachine is offline
Old 05-15-2006, 06:53 PM
  #33
-Inverted-
-Inverted-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lots of people have burned up dual motor brushless systems, one will be faster and created a load which in turn burns up the motor. Some are just lucky, same as the differentials. Im on brushless and have never replaced my differentials, I just boiled and lubricated them.
Old 05-15-2006, 08:16 PM
  #34
Racing T
Racing T's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wow thats a sick mini lst!!! wondering the speed of that.
Racing T is offline
Old 05-15-2006, 08:36 PM
  #35
brainleak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i dont think its any faster than about 40mph, Depending on the batteries but im sure the torque is outta hand I have a hyperion 6k in my MLST and its hauls two would be outta hand I'd like some vids of that.
brainleak is offline
Old 05-15-2006, 09:14 PM
  #36
-Inverted-
-Inverted-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hehe, The front end is off for repair, but you get the picture.
Old 05-16-2006, 07:50 AM
  #37
carmatic1
carmatic1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
im thinking about dual brushless , why cant we install the 2 motors without the pinion gears first, then pass a soft dc voltage thru the motors so that they line up, then install the pinions... then, wire them up to the same esc, because the spur gear will lock them at the same phase all the time they should behave as one single motor... of course this is assuming that the esc has unlimited output capacity or you make it so that it doesnt burn itself up...
carmatic1 is offline
Old 05-16-2006, 10:14 AM
  #38
-Inverted-
-Inverted-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Theres no point to dual brushless, the cost doesnt weigh out the performance increase in the first place.
Old 05-16-2006, 10:54 AM
  #39
Mr. Mugen
Mr. Mugen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you do your homework you will find that inverted is right. There is no sense in it. They WILL fight each other. There is no way around it.
Mr. Mugen is offline
Old 05-17-2006, 07:17 AM
  #40
Lilredmachine
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You know those kids that seem to drift through school without ever doing any homework? They go on to have dual brushless MLSTs. What's the advantage? Tart value and the ability to use stupid gearing thanks to the monster torque. The disadvantages are extra weight and power usage. But it does work, experience has proved this, not theory.
Old 05-17-2006, 07:39 AM
  #41
Mr. Mugen
Mr. Mugen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOL
Old 05-17-2006, 10:49 AM
  #42
Lilredmachine
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BeatYourTruck.com's latest project is a dual mamba lipo powered Mlst, should be interesting to see how it turns out, eh?
Old 05-20-2006, 10:45 PM
  #43
rcMitch71
rcMitch71's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Inverted, have you done some more testing with your $1 motor?
rcMitch71 is offline
Old 05-20-2006, 10:59 PM
  #44
-Inverted-
-Inverted-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not yet, but I will this memorial weekend, most likely sooner, I got a nice radio so I just need to rebuild it and then I can get some information.
Old 05-26-2006, 02:09 PM
  #45
sit1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Inverted, I saw you solder the battery with thicker wire and then a dean plug, what kind of battery is that? Why did you do that? Im just curious. [8D]
sit1 is offline
Old 05-29-2006, 02:47 PM
  #46
rcMitch71
rcMitch71's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool, it will be interesting to see how it works out.
Old 05-29-2006, 06:26 PM
  #47
.robb.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a Mamba-25 Competition X in my Mini LST. 33mph with 6cell, 50ish with 4cell.
.robb. is offline
Old 05-29-2006, 10:15 PM
  #48
-Inverted-
-Inverted-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah I don't think so.....
Old 05-29-2006, 10:18 PM
  #49
-Inverted-
-Inverted-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's just the stock battery, stock wire gauge. I put on Deans because my wires were melting and it lowers resistance.
Old 05-29-2006, 11:58 PM
  #50
unseen1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if you run a mamba which willl go first the motor or the ESC because my brother is going to get a mamba for his mlst and i was wondering what i could salvage after he ruins it?
unseen1 is offline
