rc18t on dirt
rc18t on dirt
what would i have to do to run my rc18mt on dirt. would i just have to put a piece of lexan over the motor and put a gear cover over the gears? go to drivenpro.net i would of done a link but i have no clue how.
RE: rc18t on dirt
well it's just every time i do drive it in dirt the dirt gets stuck in the motor and it changes the pitch of the motor and slows it down.is that normal or a problem.
AZ
RE: rc18t on dirt
Get this. http://www.drivenpro.net/index.php?s=store&pn=101 I run in lose dirt and gravel and have killed a 280 motor and a 370 from the little bits of sand and rocks that get in the gears. It will save you alot of money.
MA
RE: rc18t on dirt
Never put anything over the motor unless it's a heatsink. It'll just create excess heat and lessen it's life. The gear cover is all you need. And always have spare spur gears on hand. Even if rocks don't get in there, they will wear eventually, and there's nothing worse than waiting for a measly sub $5 part to arrive in the mail.
RE: rc18t on dirt
Lynxstrife, i thought about the gear cover from driven productions but i wasn't sure how well it would work. if you have it can you tell me how well it works
AZ
RE: rc18t on dirt
To me its some thing that is needed for the RC18T. Since it has no gear cover at all. I have ruined a few motors from just a small pebble wearing out the bearing or busting a large number of spurs. The gear cover from DP is a high quality and easy to install. When i get my camera back i will post some pics of it on my truck. But if you want to save your self from costly repairs down that road, i would get one. And while your at it get the hop-up for the steering that they offer. Its a NOTICABLE diffrence.
RE: rc18t on dirt
thanx, i'm going to get the gear cover but where should i get it from, dp or some place else? also how does it improve the steering?
RE: rc18t on dirt
ORIGINAL: emaxxbasher
would i need one of these for my rc18mt?
