motor dies over bumps???
CA
hi, its me again, with another odd problem, i have a pretty much stock rc18mt and when i hit a bump, (rock or pebble) the forward or backward, stops, then starts back up in like half a second. I have tried holding it and shaking it, nothing happened, then moved around all the wires...nothing happened, the motor just kept going strong. any ideas of this one?
thanks
thanks
RE: motor dies over bumps???
If you are using stock battery connectors....change them to deans. If you have deans already your motor brushes are probably hanging up....if so ....clean your motor. Hope one of these help.
