what will i need to do to my mini t to put a 8000 mamba motor and esc
i an thinking about buying a mamba 8000 and the esc what will i need to do to the mini t
AZ
RE: what will i need to do to my mini t to put a 8000 mamba motor and esc
Good choice.First you will want to upgrade the servo, i went with an eflite s-75.Then you will need to upgrade your transmitter and receiver pack as the stock one will not work.The mamba is a direct fit for the mini-t no modifing needed.Then it's just a matter of spur gear,pinion gear,oil filled shocks,and rims and tires that you want to use for your driving style.
