brushless for 150$
CA
brushless for 150$
what setup can i get for 150$ THAT will let me go faster than any of the mt and most of the sedans at my clubs favorite spot (a parking lot with home made jumps) i want a lot of speed and performance i also need a battery (all for the min-t)
CA
RE: brushless for 150$
For absolutely ridiculous performance, get the Quark ESC and the Dynamite C4 9200kv. It will be pretty much uncontrollable, but it will be bloody quick.
CA
ORIGINAL: BTallack
ORIGINAL: -Inverted-
The reason I didn't reccomend that setup is because it would be going over his budget.
ORIGINAL: BTallack
CA
ORIGINAL: ����ߴ����
but he just said faster and 90 for the esc and 60 for the motor is at his limit W/O shipping
CA
ya so the 8000 setup is pretty fast. and a 3-5cell lipo where is the cheapest lipo sight? any specifc brand recomendations? i really apreciate all the imput (since im new to using this forum i used to have to ask idiots at my lhs for advice and they would recomend the most expensive product in the store and try sell it to me telling me it is the only solution.) this is much much better thnx
ORIGINAL: hissyfit10
The tranny will not explode if you have alum. gear box. I ran 4 and 5 cell lipo in one of my mini-t's with no explosions. However you need a set of flip down binoculars to drive it..lol. It gets away from you fast! You can hit over 100mph with 5 cell lipo and the 8000 mamba I did[8D]
ORIGINAL: Mr. Mugen
HI
what lipo should i run in my rc18t? and how fast will [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJZ8&P=FR]this [/link] make the mamba 8000 go???
i dont know how fast it will go on a 6cell but on [link=http://www.b-p-p.com/proddetail.php?prod=h_Hyp1500_3s]this[/link] lipo it will be ballistic i would recommend that lipo, it is a direct drop
HI
how bout for a mini lst what set up should i go with including motor, esc drivetrain etc? i'm very new to 1/18th scale, i've been only into nitro, help a bratha out, thanks
TX
ORIGINAL: Mr. Mugen
CA
As for the 100mph setup, I don't think it would be too difficult to beat the current speed record, a 5 cell li-po with a fast motor (C4 9200 or the Lehner Troy carries), shove all that in a carbon fiber m18 and you should be set.
CA
Inverted if it were that easy it would've been done... the thing is with a light chassis like a mini it WILL TAKE OFF and if you have the wrong wing/body it will either give not enough or too much downforce... then theres todays tires... not really up to the task of handeling over 100k RPM's even foams will blow apart... the truth is theres really no way it can get a mini over 90... unless it is all custom, basically dragging on the ground, custom tires, custom body... you get the point
CA
ORIGINAL: Doahh
