parts for a rc18t
MA
parts for a rc18t
I just bought a rc18t at my LHS for $15 it only had the basics (frame, body, a-arms, diff cases, driveshaft, support brace, shock towers, and front and rear hubs w/ outer axles.) I picked up a lot parts for it off another racer at my local track (diff cups and gears, tie rods, dogbone axles, and full ball bearing set, spur gear, and tires) for $6. Ialso picked up a Hitec HS-56 micro servo for it. that was $30. what else do i need? this is my first 1/18th, i've been racing 1/10th buggies and trucks for a coupleyears now. I'm on a small budget so stock parts are mostly what i'm looking for.
RE: parts for a rc18t
If you go onto the team associated web-site it might have a manual on the site to look at all the paarts in the manual are stock. if all else fails u could get the part # and just order one
MA
I've got the manual but I've got another question. brushed or brushless? I could get a brushed motor for $10 or I could buy a used mamba brushless motor(minus the speed control) for $60. another question is how much is a brushless speed control?
CA
http://b-p-p.com/proddetail.php?prod=1_Q22Mamba
MA
how much $ does it run I was gunna pick up a LRP Quantum Micro 2 new for $50 and a reedy 19t spec motor or if I got a little extra money I was gunna get a Tekin Extream Rage new for $160
CA
ORIGINAL: 4wd13
