OFFICIAL MINI-T THREAD!!!
#727
RE: OFFICIAL MINI-T THREAD!!!
ORIGINAL: neiloid
Losi Street Meats are a good tarmac tyre and look great on black RPM rims. Good grip and good wear rates too.
I will give the meats a try since most of my driving is on the road.
#728
Just got my hitec HS-55 installed and I got a couple questions.
1 If the gears strip can I replace them with the metal gears from the HS-5055.
2 What is a cheap motor that I can throw in it. I dont need anything faster than the stock just something to have as a backup incase the stock motor dies. I will be going brushless but want to teach my 6 and 9 yr old with the stock motor.
#729
1. If the gears strip then I would just buy an HS5055, HS65MG or HS81MG (need to mod the chassis slightly) as replacing gears on micro servos is a PITA.
2. If the stock motor is fast enough for you before you go brushless then I would just get another stocker as they are cheap as chips. Might be an idea to hold off going brushless as there are good brushed motors for the Mini-T. I had a CC 6800 in my Mini-T but I took it out and replaced it with a[link=http://www.rcplanet.com/Team_Orion_Baja_Micro_Modified_Motor_Mini_T_p/ori20911.htm]Team Orion Micro Modified Baja[/link] which I much prefer to the brushed motor. If you just want a speed king drag racer then go brushless but I would look at motors the 5400 and run it on a [link=http://www.cheapbatterypacks.com/product/449/Elite-1300-74V-35C-Lipo-Pack.aspx]good quality 2S lipo[/link]. Advantage of staying brushed is that you can run it off the stock ESC. If you are going to run lipo then get a lipo alarm if you are using the stock ESC [X(]
#730
oh yeah its going to be awhile before I go brushless.
Im looking at brushed motor options and I may just grab a few venom fireballs for the kids to trash and the baja for me to mess with.
Im trying to get a cheap roller on ebay so I can slowly build it up and eventually just give this 1 to th kids and keep the built up 1 for myself.
I blew through my first set of stock tires in just a few runs so brushless would just eat the tires quickly, I wouldnt mind but the wife wont be happy if im buying a new set of tires every 2 days.
I drive on and off the road so im looking at the DT stock tires they look like they will do both and hold up. any opinions ?
#732
MD
ORIGINAL: EReVoNuT
the dt tires are decent on street and dirt . they last a while but you will sacrifice some traction for longer lasting tread. ohh 1 more thing you may want to grab a couple front bumpers with kids driving them they will save you some front end parts
and your question about the hs55 gears i am not sure if the 5055 metal gears are the same size as the plastic , as neiloid mentioned the gears can be a pain to get right but it is do able . i will try to find out if you can replace the plastic gear 55 with 5055 metal gears hope that helps and enjoy its good to see people getting there kids involved in the hobby
#733
[link=http://cgi.ebay.co.uk/Orion-20911-Baja-Micro-Modified-Motor-Mini-T-New-/270694016726?pt=Radio_Control_Parts_Accessories&hash=item3f069ee6d6]Hop Me Up[/link] still sell the Baja motor and the shaft may be short but Losi and other aluminium pinions do fit. In this picture the end of the shaft is flush with the end of the pinion (Hot Racing if memory serves). It may limit your choice of pinion manufacturer but not the number of teeth on the pinion and I've not had a trouble with this pinion. Choice of pinion provider may or may not be a concern to you but it is a valid point to have raised.
Hope this helps...
Hope this helps...
#734
ORIGINAL: neiloid
Hope this helps...
Hope this helps...
Thanks neiloid good info to know.
#735
My pleasure. My Mini T with the Baja motor is great fun, loads of low down torque and good straight line speed and off road it picks up really well which is great in tight surroundings.
#736
#737
MD
wow i didnt know the baja was still for sale anywhere price is kinda high but i may grab one just to have . they make good power alot like the old peak racing chubby
great info neiloid
great info neiloid
#739
MLST and crawler tyres are huge compared to the mini T wheels and will not fit. As for the mini Sprint I do not know as I do not own one. Sorry.
#742
ORIGINAL: mrbonez
the mini sprint tires work if there from a losi mini sprint but those are losi street meats as discussed earlier
Hers a link to them there dirt oval tires. I doubt I will get them the street meats have a better pattern IMO.
http://www.losi.com/Search/Default.a...hTerm=110_Oval
#744
ORIGINAL: EReVoNuT
Yeah I dont think I want bigger tires cause from what I understand it will make it a bit slower.
What about bodies ? what fits ?
In the pictures the black RPM wheels are with Street Meats and the white RPM wheels are Proline Dirt Hawgs.
#745
MD
nice love the panel truck and the baja body nice touch with the bully rims. the beetle body looks like a losi baja body . very sweet mini t's
#746
Yeah I have been out of the RC scene for 2 or so years , what happen to proline ? I have only found 1 pair of the dirt hawgs on Ebay and proline doesnt even have them on there site.?!?
I ordered some cheap GPM mad basher tires but I really wanted the dirt hawgs , I go from dirt to pavement so I need something that doesnt get worn out quick but at the same time grabs traction in dirt. I know the mashers wear a bit quicker on pavement.
#747
I don't think it's Proline, they still make loads of stuff. I think it's more the mini T, others have come along and manufacturers have pulled out of the model. Same with the MLST2.
Glad you like the bodies. Both need the extended body mounts to run them.
#748
Well proline doesn't seem to be making any 1/18th scale tires. at least not on there site.
Any cheap Brushless ESC out there ? I may be getting a good deal on a 1/18 losi BL motor.
#749
MD
heres a link to a cheap 18 amp bl esc http://www.hobbypartz.com/ezrun-18a-...or-rc-car.html
you can find them on ebay to also look for the 25 amp 1/18th car bl esc the 18amp will work fine but the 25 amp is a little better and will run a higher kv motor more efficiently
#750
Thanks MRbonez
I was looking at ezrun but seems like it would talk awhile to ship but if I cant find anything closer I guess I will order the 25 amp .
