gpm racing diff gears?
RE: gpm racing diff gears?
GPM suck, i had a GPM spur in my TL01 and it stripped and so did the pinion in under 5 mins of drifting (didnt even hit anything)[]
ORIGINAL: KamikazeParanoia
I have been running the GPM gears since thier release. If you pair them with the GPM gearboxes they do very well. Not so great in the stock boxes, but still workable. I managed to get 10 packs through my MLST with a wraith/quark combo and 2.2" rims and tires. That is about 9.99 battery packs longer than the stock gears would have lasted! They are definately not unbreakable, but a darn sight better than the stock gears.
J.
83 gt, i believe someone wanted you in the "Is one18th Done for Anyone?" Its about a sale from one18th and since the site is down something something.
how hard is it to get the mlst diff. gears from gpm and what is the price for them? i have summited an order but no answer from them as fo yet?
Wait for a response from GPM or pay a couple bucks extra and get them from www.thetoyz.com. GPM is easy to work with, but you also have to remember the time difference is huge. Usually they get back to me within 24 hours.
CA
I just got 2 of those diffs. The screws are so small. Anyone know of a screwdiver set that can open them? I guess I have to take one of those eye glass screwdrivers to open up the diffs.
MI
ORIGINAL: cnguyen831
You can find "jewler's" or "precision" screwdrivers at any Wal Mart, Radio Shack, or Sear's.
ive just installed bearings and drivecups on one of these diffs (stock drivecups and fullforcerc bearings) , and i must say there is a huge bind in the spider gears, like the 2 drivecup gears are squeezing against the spider gears ... they still turn, but not without alot of grinding...i cant even get the screw panels all the way in.... im scared that at this rate the spider gears are gonna melt when i use these diffs...
Hrm. Make sure they're meshing correctly. A couple of mine were that way, a bit stiff and allmost "clicky" feeling when you spin the outdrives opposite directions. They worked in just fine.
J.
J.
