OFFICIAL TeamVTX Truggy/Buggy Thread
RE: OFFICIAL TeamVTX Truggy/Buggy Thread
ORIGINAL: UNITED RC
Everyone,
I just installed the Trinity .095 Drake Motor...fits like a glove! Waiting on some fuel tubing so I can break it in.
I will let you know how it goes and the increase in performance.
Everyone,
What servos are you running btw?
#32
NJ
hey Ed, I was looking into gettign one of these for myself. What do you think of it? Im not used to nitro powered. Where did you get yours?
Frank
quote]ORIGINAL: 1badmaro
Had the same problem with mine. I made the mistake of turning the adjustment screw all the way in and that pushed the check ball into the spring. So I had to take the whole 2spd apart to fix it. So what you want to do is turn the set screw out till it stops then turn it in a 1/2 turn at a time (this worked for me) till the shift point is were you like it. More info can be found at www.teamvtx.com forum in the FQA. hope this helps.
[/quote]
Frank
[/quote]
#33
FL
ORIGINAL: -Inverted-
Yep.
Yep.
Hey, about Krystal motor.....even if I send you one.....we are most likely not going to reproduce them. Are you still interested?
Regarding the servo, is your YEP referring to the 100% certainty that it will fit in the truggy steering and throttle servo location?
URC
#34
CA
ORIGINAL: UNITED RC
Inverted,
URC
Yep.
Yep.
URC
As far as the servo, I have no idea if it will direct drop-in. Dokioto asked what servos people use in the 18t, I said the HS65, he linked, and I said "yep" confirming the linked the mentioned servo. I think the JR 241 servos might fit, I think he will try those and report back.
#37
FL
I think the truggy is a bit wider, and of course, a different body. Other than that...i think that is the only difference.
#39
PA
Frank I like the truggy alot . I had a few small issues with it but nothing major. A few screws fell out (prob my fault lol) never checked them when it was new. However i contacted Greg from VTX and he took care of me right away, they have great customer service. I must say i was suprised... this little thing rips. Me and my son had it and my HPI rs4 evo out sunday, and from a stop the evo would kill it but from a roll it was close. The HPI hit 44mph on the venom speed meter and that little truck wasnt far behind!!! Have not had it off road much been to cold.
#41
PA
Break in wasn't to bad it just takes time. I got both the truggy and the buggy at hobby town in Springfield PA on Baltimore pike. If you get one let me know I would be more than happy to help you out. I have been doing nitro's since the mid 80's. I still have my first 2 nitro cars an old kyosho assault and a 1/8 burns both still run and are in great shape. You still live in philly?
#42
FL
VTX does have great customer service. my driver side steering rod/column/pole locked up....and GW is sending me a new one. Very great service!!!
#43
NJ
Ed, Yea Im in the NE.. I used to race in the 80's too. Electric only... see my thread with my old car I just got running.. Is that place in Springfiels big? I was gonna take a trip there soon.. They had the VTX in stock? How much??
http://www.rcuniverse.com/forum/m_5352809/tm.htm
ORIGINAL: 1badmaro
#44
PA
Cool car!! Yea its pretty big they have alot of cool stuff in stock. They had 1 truggy and 1 buggy in stock before Xmas and i bought them both. call them http://springfieldpa.hobbytown.com/
#46
ORIGINAL: Dokioto
Yep, will report back...
ORIGINAL: -Inverted
#47
CA
So the .095 trinity motor will fit into the VTX ??? how much did the motor cost and was it really a drop in set up or were a lot of changes to make??
#48
Well my Dad just ordered one of these VTX Truggys from rc-nation. Once it gets here and the weather warms up we will do a little performance testing between it and my Trinity Next. I think I will like running with him better once he has this 1/16 scale truck, he always seems to run-over my 1/16 scale with his 1/8 scale trucks
#49
FL
ORIGINAL: Dokioto
These servo don't fit the servo horns (if that is what it is called). The gear in the servo is to big.
URC
#50
FL
ORIGINAL: rcmxsports
(1) Engine, not the draked version
(1) .095 engine mount (alum) - this is NECESSARY. By default, the trinty engine mounts with 3 bolts, and the VTX uses a 4 bolt pattern. The engine mount allows you to mount the engine using the stock 4 bolt pattern on the chassis
(1) Manifold and pipe for the engine - BUT, I will say that this is a POS item. I have TONS of leakage coming out of the rubber coupler where the pipe meets the manifold. The header/manifold does not seem to be secured as I would like it to be either.
The one thing that I might see as a slight mod is extending the wire that secures the pipe to the chassis. I cant comment on this yet, as I have not settled on the pipe issue. I will let you know. As far as the engine...it is a direct fit...I even had to use the same brass collar off the stock engine and same flywheel.
URC
