OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
#2478
RE: OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
nice.
i just got bearings for my micro-t....i can't wait for the testing to begin!!
so i have the 3 racing 10 bearing set....are the two "tranny" bearings really not needed? where do they go? on the diff?
hmmm....thats what i was told. but i'm not sure if it's worth disassembly to remove bearings and install....bearings.
how would i know which are better? hah...
#2479
hey guys,
I'm kinda new to R/C, rite now i'm mugging around with the "Team-Losy" Micro-T. When i surf the net, I found out there is a option part which is made by 3racing. It's the Alu. Oil Damper set. Does anyone try them out? I realy need to know coz they look sooooo tempting to me~~ CHeers!
[link=http://www.3racing.com.hk/x_products.jsp?x_carkit_id=63&x_title=Optional%20Parts%20for%20Team%20Losi%20MIC RO-T]3Racing Micro-T parts[/link]
#2480
ON, CANADA
they will be better than stock......Well I finally managed to break something on this little truck....did about 10 cartwheels and broke the rear hub carrier and lost the dogbone...looked for it for 30 minutes no luck...I gotta replace it so is stock my only option?
#2481
the whole rear suspension setup including aftermarket dogbones OR CVD's are available...not just stock.
use a magnet and don't give up if you know where it is approximately. but the parts are cheap so you might just buy new parts depending on the availability of them.
and rotten egg - i've heard that vasalene in the stockers works wonders. i havent tried it myself though...but you might give that a few tries. i'm going to soon once i have time to mess with the thing.
#2482
ON, CANADA
thanks for the heads up......I tried putting heavy grease in the stock friction shocks and it does not work....what did work was stronger springs. I robbed to ballpoint pens of the spring and they fit perfectly and stiffen the rear end quite noticeibly. Then I took the rear stock springs and put 'em on the front..works awesome
#2483
PA
I just got my micro t, i am looking to upgrade the motor. I just baught the li-po battery for it and need more power. Any susgestions on a hop-up motor? is there even one that fits?
#2484
there is a ball bearing motor that adds a noticable speed increase.
here is a link
http://www.thetoyz.com/cart/thetoyz_...name=MICRO%20T
i think there is a brushless motor that belongs in a plan or boat or sumthin that can fit with a few adjustments. (((((((((((I THINK
here is a link
#2485
ORIGINAL: fm2h3
here is a link
here is a link
sooooo...wouldn't that mean it has brass bushings?
it says they dont have ball bearings, so...is it another type of actual bearing, or is brass bearing just another lamo term for brass bushing...?
#2488
Anyone else have trouble putting the losi lipo in the micro-t. The screw bosses for the cover get in the way.
#2489
the lipo is bigger than the stocker? do you have a picture? try re-orienting it to see if maybe you have it in the wrong way...
#2490
CA
it will fit. you may have to trim a little of the blue. just start with one end, and push the other end in.
#2491
I finally got it in. I was holding my tongue on the left side of my mouth instead of the right. Tight fit though.
I also installed the TGN carbon bumper. Pics when I have time.
#2493
IL
Here are some pics of my Micro B with the X-citer body painted by me ....
So far its got the 7.4v LiPo , the Atomic BB motor , the 3 Racing gearbox , and bearings on the wheels .
I also did my own antenna mod from an alloy tube holder I had from my spare parts box .....
#2494
awesome stuff, it would be great if you could get some high-res photos, namely of the body, i like it! was it hard to mask off such a tiny body? or did you use a paintbrush?
that's an idea...maybe i'll paint my hilux body, and get a nice bumper for the chassis, then i'll have the perfect prerunner. I'm hoping to get the body drilled and mounted this weekend, i just have to make sure i dont damage the antenna which is showing some wear, and make the proper body fitment. its just about perfect but also has to be placed perfect to line up the wheel wells...or it looks funny.
#2496
UT
ORIGINAL: RCCanuck
If you have some extra nitro fuel tubing around you can put 2 or 3 MM pieces on your shocks as preload spacers. That way you can make the springs as hard or soft as you want. I can't remember what page it was but this tip has allready been posted once. I thoght I'd bump it though cause it worked great for me!
Has anyone gotten the losi AC charger yet for the stock batteries? I'm still wondering if they charge in 20 minutes like the DC charger does.
#2497
ok...how the heck do these work...i dont see how you could use them?? can someone tell me where they go? let's call them turnbuckle set 1, 2, and 3 from the top down. that means the flat set is set 3.
i'm just curious where they go on the truck... anyone used them? are they good? maybe they go in place of the upper rear links, the front steering rods, and the front upper links? i dont see how all this would work......
