OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
#276
My Feedback: (29)
IA
RE: OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Here is a better battery. for less.
http://www.cheapbatterypacks.com/mai...er=3&model=419
Only things is if you use this battery you have to convert everything over to Deans micro plugs. And that's a good thing.
Ron
Ron
#278
My Feedback: (29)
IA
Well, you caught me there on that one, Honestly no, I have not tried the one from killer. However I do not think there are any better 160 cells than KANS, and that is the cells used in the cheapbattertypacks.com pack. Now if Killer is using the KAN cell in, their pack then it is probably just as good. Still, there is the price issue........
Ron
Ron
#279
Thanks Ron, I guess it's to late now anyway I already ordered two of them. I'll just mess with these until I decide if I want to go lipo or not.
#281
IN
can you cut the 4th wire (orange one) on the stock servo off and then use the servo in a regular receiver?
#282
not that easy man. I'm sure there will be a mod for this though. There was one for the mini t servo. It might be the same....not sure. I use the 2s lipo at 250mah and it rocks this little car.
#284
Hi - My Micro-t had rear end squealing... just 3 days old - about 15 runs - chansed it down to pitting a drop of light oil behind the slipper on the shaft that it spins on - instantly silenced it.
#289
How long of run times do you normally get with the stock battery, thanks? And are there any upgrade motors for it?
#291
My Feedback: (29)
IA
I wasn't getting that much maybe 5 to 6 min. Then I started using my ICE charger at 0.20A and started getting close to 10 to 12 min runs.
Ron
Ron
#292
AL
If you charge at a lower amp setting, you'll get more run time. If you charge at a higher amp setting, you'll get more punch with a reduced run time.
#293
Or get a lipo and fly for 1/2 hour and charge for 15 mins You can get a AMMO BL motor for it and a micro esc and rx and servo though.
#294
My Feedback: (29)
IA
ORIGINAL: brushless
Ron
#295
My Feedback: (29)
IA
ORIGINAL: Mr. Mugen
ROn
#296
AL
ORIGINAL: 4 stroken ron
How High C can you charge these stock packs? I was a little hesitant to go above 0.20. I also have some KAN 160 Mil coming from cheapbatterypack.com. How high can I charge those KAN packs?
Ron
ORIGINAL: brushless
Ron
#297
I got my ammo bl for 30.00 and still looking for good micro esc w/rev. If I find nothing by the time my 2 bluegroove chassis get here you can bet the mamba esc will be shortened up and put in here.
#298
My Feedback: (29)
IA
ORIGINAL: Mr. Mugen
http://www.banebots.com/pc/RC-RX-4/RX-GWS4-PH
Only time will tell how well it will work. I also ordered a Futaba 3101 servo and a Novak SPY. I am staying with the brushed motor.
All this conversion just to get on the 75MHz band is going to cost around $125. Still too much to spend, for an $80.00 car.
Ron
#299
Thats the same reciever I got for mine. I got it in 75mhz and got the micro xtal set for it too. I since then bought 4 other GWS recievers for my planes. They are nice and small and are plenty good as far as quality goes. Hope you like it.
#300
My Feedback: (29)
IA
I have been using them in planes for a few years, always have worked well for me. First one on 75 band.
Ron
Ron
