OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
#3502
RE: OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
ORIGINAL: sfar785
i just picked up a LiPo, it's fast as hell now
which one did you get and what are you charging it? would be good info for new buyers.
#3503
i got the Losi LiPo and charger combo, picked it up for $50 at my LHS. I like it because it takes an hour to charge it and the charger has 2 LED's that let you know when it's fully charged. I got a 20 minute run off the 1st charge, they say the time will increase with the more times the battery is charged....but i think i fried my steering servo, gotta go get a new one tomorrow
#3504
PA
ORIGINAL: irlsh
the threaded axles are nice but not needed as top 5, BUt the first time u lose a c-clip lol you will want the threaded axles lol
In the box it comes with an extra 4
#3505
i just meant when you have to start dealing with the clips u will agrivate yourself and just get the axles lol
#3506
PA
lol yea.... I stripped out one of my DT wheels that was on my T.... So I have baja tires and wheels on my micro-t with DT front tires lol. the right rear just rounded out.....
#3507
IN
ORIGINAL: CrazyEh
Hey guys,
Question.. I'm going to pickup a micro DT next week.. What top 5 upgrades to help the truck run better, would you suggest?
Hey guys,
sorry i ramble alot! haha
#3508
IN
ORIGINAL: sfar785
#3509
it just wont work at all...i can move it with my fingers, but it acts like there isn't any power running to it.
#3510
IN
are any of ur wires look like they are lose of the plug? iv personally never had a servo just stop working without it being a problem with the reciever, which in the case of the micro it would be the pcb. hopefully its just ur servo thou.
#3511
i hope it's the servo too...but it was working fine until i unplugged the LiPo and charged it, once i plugged it back in, the steering servo was gone.
#3512
IN
ah, thats probably ur pcb then man. I know when i got my lipo in my micro t the lipo heated up the pcb and melted the plug that servo hooks up to. my dt never had that problem then, i would try to get a new servo and if that doesnt work then I would call Losi about sending u a pcb. They really nice when it comes to warrenty man. I know I was over by a week on mine and they replaced my pcb free of charge.
#3514
PA
..... i was 1/2 way thri my lipo pack and the motor stopped.... it wasnt hot. so i let it rest a wile, charged the batt. went to do it again and it goes for about 5 secons then stops... I tried a BRAND new motor and still 5 sends then it stops.... The steering if fine but no motor.. I checked all the soldures and they are fine....
#3516
IN
ORIGINAL: madmax22
#3517
ORIGINAL: madmax22
before you go ripping out your ESC make sure thats the problem . you can get a little motor out of some old device and test it. or get a hot wire tester from radio shack there good tto have anyways, but i would just use some old motor off of anything not to large and check to see if it runs it.
#3519
ORIGINAL: madmax22
i tired a couple motors from all of our micro's same thing......
#3521
ORIGINAL: sfar785
my Micro is screwed...i need to go get a new steering servo tomorrow after work
#3522
IN
Sad racing morning it has been. My friends and I decided to have a little racing this morning around 5am. We all got our cars charged and setup. 1 of my Dt's had been running a little weird through out the day before and I ran over the tranny and everything, but everything was ok. So I decieded to go ahead and run it instead of my other, bad choice! About 10 mins into my pack the car flys by on the straight and I hear a strange hissing noise. Instantly I pull the car off the track and begin to walk towards it, BOOM! Literally the car explodes!!! My **** freaks out! My car is in flames and im freaking out! luckly my buddy grabs something and puts it out. Well whats left is a big pile of melted plastic and poo haha. Sucks. So my guess is that the wiring on the pcb that runs to the battery may have strayed and touched. Causing the battery to short circut, meaning bad for the Lipo's. SoOoOo, I called Losi told them of the problem and luckly I was running one of there packs. Told me to send in the car and a lift/recipt of everything I had on the car and they would replace/refund me of everything!! Sweet! Love Tha Losi!
#3523
ORIGINAL: HandicappMan111
Hey man you might want to grab a 3racing gearbox. they have them at TheToyz.com. They go like 15 something and if ur new to the site they give a 10% off ur first order. Reason I say get the gearbox is because the brass bushings in the tranny wear really easy! then all the shavings will go into ur diff and strip ur bevel gears. The tranny that 3racing offers has bearings that support the top shaft instead of the bushings. With the tranny box thou ull need to get a small washer or something to shim it. I used a small piece of fuel tubing i had laying around. just a heads up! cause after a while with a lipo ull notice a lot of play on ur spur.
ORIGINAL: CrazyEh
Hey guys,
Hey guys,
#3524
#3525
Woohoo... on Thursday I'll be picking up 3 mirco dt's along with threaded axles, bearings, and lipos.. can't wait!.. thanks for the advice
