OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
#1301
RE: OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
how much is a bb engine over in america and how much is a brushless engine?
and where can you buy all those aluminium parts?
and also since i got my car ive noticed that the gears have worn down heaps and the inside of the case is covered in white plastic powder. and can you get aluminium gears?
any help will be most appreciated. cheers
#1302
is it just me or when you try to spin the rear wheels when its off, is difficult. or is it just the engine turning over.
#1303
My Feedback: (15)
NJ
ORIGINAL: nitro _ burner
Either your diff isn't broken in or there is a problem with it. When you turn one wheel the other should spin in the opposite direction and feel very smooth. The diffs in these seem to be very inconsistant.
#1304
Did you try to loosen the tranny screws most of the time there just overtightened. Also you should look for hair and other stuff binding the tranny.
#1305
AZ
yes they do make aluminum main gears, there buy hot racing and let me tell you there great.
i also opened up the tranny and put a bunch of lithium grease on the gears, seems to help. and yes with the stock motor its pretty tight on the ground, with my BB motor its alot better, i can "coast" through turns alot better
#1306
AK
Dust is the norm in the gearbox (for me at least).
#1307
NY
Does anyone know if you can buy the clear steering links that come in the new Micro T boxes? I just broke one and I relly like them.
#1308
My Feedback: (15)
NJ
ORIGINAL: associatedelectric
You can buy aluminum ones or make your own using small zip-ties.
#1310
thanks alot for all your help. when i spin wheel one way the other spins the oppisite way pretty smoothly (it must have been the engine that i was thinking about before).
where and what are the tranny screws?
and when i bought my micro t it came with 2 of those new clear steering links.
also what im trying to do is first upgrade my engine and my battery so when i upgrade to most aluminium components or parts it will be able to move along with ease despite the extra weight. does this sound like a good plan?
assiciatedelectric if you go on ebay and yype in micro t. you will find reinforced steering links that people have made.
have a look.
http://cgi.ebay.com/TEAM-LOSI-MICRO-...QQcmdZViewItem
have a look.
#1313
My Feedback: (15)
NJ
yeh but if they are the stock ones they will break just as eaisily.
Why not get the aluminum ons??
#1316
My Feedback: (15)
NJ
do you know how to take the e clips off of the wheels?
i cant do it[&:]
i cant do it[&:]
#1317
ok kool ill try that.
but ill have to get some very much so needle point pliers.......
i also have to get some tiny screw drivers and a tool to undo the nut on the main gear.....
#1318
hey where do you guys buy all of your hop-ups?
over the net if so what site?
or from a local store?
#1319
AZ
killerhobbies is where i got my aluminum. and also nitro burner, that does sound like a good idea, i would only buy aluminum parts that you really neeed and keep breaking the stock one of it. otherwise i dont really see the need for them other than looks. also, if you get the bb motor and liop which is a must, GET A WHEELIE BAR you WIlL nedd it.
Update on the rubbermaid chassis: i made amother one (3rds the charm lol) and instead of gluing the parts from the stock chassis, i bought a drill bit to make little tiny holes, overall its about a half inch longer than stock and accomodates my aftermarket parts quite well.
#1321
NY
Go figure, as soon as I do the zip tie mod my car glitches and slames into the bottom of my couch and the hub breaks. [sm=disappointed.gif] I can't win.
#1322
AZ
well see, thats definitely a part to get aluminum, thats why i dont like to run mine inside.
#1323
well i want to make it look realy kool so i will hop-up the most visible parts that are also vulernable to breaking. case that fits over the gears(i think its called trans case?),front and rear arms, front and rear camber bars,threaded wheel thinggy(is a must anyway) and aluminium rims and new wheels.
also where can you buy bb engine from? i know that you can buy the lipo battery and charger over the net.
cheers
cheers
#1324
im looking at these sites to buy my parts from.
http://www.killerhobbies.com/items/t...cro-t/list.htm
http://www.thetoyz.com/cart/thetoyz_...name=MICRO%20T
are these sites trust worthy and have you guys had any problems or advice for buying parts.
and how much is it to transport items to australia?
#1325
oohhhh crap....
i was trying to put the e-clip back on the wheel and PING!! off it goes. now i have to buy a new set.
